Taurus Transmission Problems - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-09-2010, 09:30 AM   #1
Rewards Points: 27
Taurus transmission problems
I have a 2007 Taurus. I was driving down the street and the car seemed like it just slipped into neutral on its own. When you put it into any gear it just sits there like it is in neutral. The fluid is fine just wont shift into anything. When you put it in park you cant push it like normal but all other gears are like neutral. Any suggestions?
ROBBYT3 is offline   Reply With Quote
Old 04-09-2010, 11:11 AM   #2
Newer transmissions are electronically controlled. So check fuses! Your owner's manual should say where all the fuses are located (multiple locations sometimes).
And check *all* fuses. Could be a computer module (one of 24 or more computer modules) which needs to send some information to the transmission computer and is not directly connected to the transmission. Just check one fuse at a time, then replace it. They you will not get them mixed up.
How to check fuses...
http://www.dinosaurelectronics.com/Test_Fuse.htm
Also check the battery. Computers need a certain voltage to work properly...
Check the battery voltage with a multimeter.
A fully charged battery would read 12.65 volts or higher. Use DC volts 20 on the meter.
The battery should read 12 something volts with just the ignition on (not started).
Then start it and it should then read 13/14 volts at the battery. This is the alternator kicking in and charging the battery.
Then measure the voltage inside the vehicle as well. Check from the center of the cigarette lighter to ground and you should get about the same voltage as at the battery. Check with just the ignition on and also with the vehicle running like above.
Other than that, you would need to take it to the dealer and they would have all the latest electronic test equipment to see what was going on.
Billy_Bob is offline   Reply With Quote
Old 04-09-2010, 12:50 PM   #3
Rewards Points: 27
I really appreciate the responce. The first thing I checked were the fuses but you know what? I did notice that the negative terminal on the battery was pretty corroded. The only reason I did not clean it the last time I serviced it was because the bolt will have to be sacrificed in order to get it off. But that will be next. I knew that newer vehicles were pretty sensitive but you don't think that they would be that sensitive. Hopefully that will clear the problem!
Old 04-09-2010, 01:17 PM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
a slipping tranny usually means it's done. How many miles on it? It should be covered by 5/60 drivetrain warranty.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-09-2010, 01:48 PM   #5
Rewards Points: 27
There is no slipping to it. It just came out of gear and wont go back in. No warning, no strange sounds. It has less than 50,000 miles on it.
Old 04-09-2010, 02:01 PM   #6
Rewards Points: 150
nuetral safety switch? (switch on top of tranny, where linkage from shifter goes).
also check out http://www.taurusclub.com
those guys are pretty good over there, and lots of great info. I have used it many times for my '97 Sable.
(BTW... 210K miles original trans.... completely unheard of)
Good Luck
TJ_in_IL is offline   Reply With Quote
Old 04-09-2010, 10:54 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
The Taurus/Sable has a bad history of tranny problems. A friend who works at a local Ford dealer says they don't even try to rebuild them, they just replace them.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-22-2010, 03:10 PM   #8
Rewards Points: 27
I replaced the neutral switch and it made no difference at all. I talked to a mechanic on a local radio show and he said possibly the axle was broken. I dont know.
Old 04-22-2010, 08:44 PM   #9
Rewards Points: 150
I would seriously rethink that one, since it is a front wheel drive, no axle, per se. Sounds more now like a fried trans.
Old 04-23-2010, 05:22 AM   #10
I have gas!
There are two axles (half shafts). There is a possibility that one of them is broken but I doubt it and you probably would have heard something. Doesn't the Taurus have a 60k mile drive train warranty?
Last edited by Clutchcargo; 04-23-2010 at 07:35 AM. Reason: I need grammer lessons.
Old 04-23-2010, 08:14 AM   #11
Rewards Points: 27
I said earlier that it has less than 50,000 miles on it but I was wrong. It has 68,000 miles on it. Just my luck.
Old 04-26-2010, 10:29 AM   #12
Grofica's Avatar
you said the fluid was fine? i am guessing you ment the level... is it black? are there silver flakes in it? does it smell burnt? or is it bright red?
Grofica is offline   Reply With Quote
Old 04-26-2010, 12:57 PM   #13
Rewards Points: 27
The fluid color and level are fine.
Old 05-25-2010, 04:03 PM   #14
Rewards Points: 27
Just to let everyone know, I had the car repaired and it was the torque converter. Had it replaced and so far no more problems. I thank everyone for their help.
Old 11-30-2011, 03:54 PM   #15
Hi,
I am having almost the exact same problem with my 07 Taurus. I was driving when it seemed to go into neutral while making a revved engine sound. I had enough momentum to pull over and park. The car acted the same way in every gear: forward and reverse...out of curiosity, how much did replacing the torque converter cost? How did they finally diagnose the issue?
Thanks,
Frustrated and rideless...
07taurusowner is offline   Reply With Quote
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
Multiple problems in 3 year old house I just purchased swenard Plumbing 12 08-31-2009 03:53 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
