Taurus Trans Not Engaging - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-26-2013, 08:42 AM   #1
I got a 1998 Ford Taurus that is not shifting into any of the forward gears. It shifts into reverse fine. Before this happened, no gears were missing or skipping, but it would occasionally shift into neutral or a lower gear for a brief moment, then back into the correct gear. A friend of mine said that it sounds like a problem in the shifting column. Any ideas?
ashbroco is offline   Reply With Quote
Old 07-26-2013, 10:15 AM   #2
Rewards Points: 16
In the old days, use to be that when a trans went out, the forward gears would go first?
Did you change the oil or service in any way?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Headlight Switch for 2000 Ford Taurus sweaty Automotive Repairs 1 05-27-2013 10:00 AM
1998 Ford Taurus Brakes ashbroco Automotive Repairs 4 05-17-2013 07:26 AM
95 Taurus electrical fire Bigplanz Automotive Repairs 2 03-27-2013 07:04 PM
2000 Ford Taurus Misfires sweaty Automotive Repairs 3 02-10-2013 11:53 PM
high voltage a on secondary side of trans hvactech54 HVAC 3 10-09-2012 10:39 PM
