Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-12-2011, 06:24 PM   #16
ukrkoz's Avatar
Synthetic Oil & Grease
Originally Posted by hyunelan2 View Post
Contrary to some common beliefs, dealer's don't make a lot of money from selling new cars. They make a lot of their money from servicing them. Open the owner's manual of your car, it will have manufacturer recommended oil change interval information in it. Usually this interval is much longer than the dealer tells you. The dealer's service department wants you in the door more frequently. If you go the recommended 7500 miles between oil changes, that's only 2 oil changes in 15K miles, where they could be billing you for 5 oil changes if you go in every 3K miles.
ditto.
dealerships are not repair shops. their bread and butter is low level workforce, short time, high volume items like oil changes, belts, etc. higher profit margin. just like teeth cleaning by your dentists. they hire a bunch of entry level folks and tell you to do it every few mths. or the infamous wisdom teeth. let us pull'm out!
no one in sane mind switches an oil taker to synthetic. every car i buy, and i buy used, is tested for oil consumption. in 2-3 000 miles, you know well enough if it's a candidate for synth, or not. if it takes oil - it's a no go. adding oil is too expensive. we have a 95 eclipse in the family that i will never even get close to synth. but the rest of our cars, and my son's cars - synth only. i do amsoil, he does royal purple, his choice. works great.
otherwise, if you do your oil changes with synth every 15 000 miles - and i do sleep well with that - it is cheaper than to do 5 000 miles with conventional oils. and that is not even the point. the point is - synthetics are plain better lubricants. BMW is not dumm to request synth oil in their engines. best i know, virtually all new models come with synth in them. thereafter, end users start justifying, usually based on $$, this or that.
alot of this is habit, stubbornness, fear, even cultural or reginal inhibitions. y'all know well enough there are chevy and ford areas in the country, or asian ones. i can tell you, from working in five states, that redneck in AL is driving a beat up Chevy or Ford, redneck here in Pacific NW - beat up VW or Civic. even better - an Opel. same goes for oils.
ukrkoz is offline   Reply With Quote
Old 04-13-2011, 02:45 PM   #17
A Little Of Everything
I typically run synthetic blend oil in the moderate months. During the 20 years we lived in Minnesota, I always ran full synthetic oil in the winter. The difference in how easily an engine turns over and starts in, -25 degree temperatures, is surprising.
I generally change my oil somewhere in the 5,000 - 7,000 mile range - partly depending on if the oil on the dipstick shows any signs of being filthy.
Basically, I keep our vehicles until they die. Currently, our "newest" vehicle has 136,000 miles & we have one with over 350,000 miles. I plan to keep doing what I'm doing.
I do think that many of the "synthetic versus dino oil" arguments are a moot point. Change your oil and filter regularly, and do the other maintenance on your vehicles in a timely fashion. THAT is the key to getting long life out of the vehicle.
DrHicks is offline   Reply With Quote
Old 04-13-2011, 11:02 PM   #18
Pro Flooring Installer
rusty baker's Avatar
I am the second owner of a 89 Riviera. 225, 000 miles, still runs like new. Had synthetic when I got it, will not change it now. Still gets 33 mpg hiway.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Synthetic Lawn - is it a DIY project? Have you done it? cody21 Landscaping & Lawn Care 1 05-09-2010 03:56 PM
Synthetic Underlayment Blues chunkylover53 Roofing 4 10-13-2009 12:43 PM
15lb felt or synthetic bronco2 Roofing 3 09-26-2009 11:31 AM
Help: Kitchen sink drain is clogged with grease cips Plumbing 4 08-10-2009 11:11 AM
Decking, Pros/Cons on wood or synthetic? Changeling Building & Construction 8 06-20-2008 07:26 PM
