Synthetic Oil And The Change Oil Light - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-16-2013, 03:57 PM   #1
I drive on average roughly 60,000 miles per year for my job. To keep my truck in good shape (Toyota Tacoma), I change my oil between 3000 and 5000 miles. I know when synthetic oil, I should be able to go further. The second I hit 5000 miles since I changed my oil, my change oil light came on. I reset it. Will it come back on if my oil is dirty since I reset it? Or will it go another 5000 miles and then automatically come on? I know I should be able to go 10 or 12 thousand with synthetic oil. I'm curious how the truck reacts though. For instance, if using regular oil, my lights comes on at 4500 or so. If I reset it without changing my oil, will it come right back on?
chadjohnston is offline   Reply With Quote
Old 09-16-2013, 04:13 PM   #2
bbo
looks like the light is strictly mileage based on a search of tacomaworld forum.
only way to know for sure about oil age intervals is to get an oil analysis. I've done one for my oil-burner jeep and it looked like it could go about 9k, but I do the 6250 interval change.
you can probably just keep resetting it whenever you change oil and it should go the 4500 to start flashing, the another 500 for solid.
bbo is offline   Reply With Quote
Old 09-16-2013, 05:42 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Mileage based.
Depending on what synthetic you are running, get some oil analysis done and see what it looks like at 5,000 miles.
Old 09-16-2013, 06:27 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If you are running fully synthetic oil your good for 7,000 to 10,000 the miles between changes.
The indicator on the dash does not know how clean or dirty your oil is. As stated it's milage based.
sublime2 is offline   Reply With Quote
Old 09-16-2013, 06:36 PM   #5
ukrkoz's Avatar
Rewards Points: 990
On a tight engine and with Amsoil, my Silverado easily did 15 000 miles and could do more, and wife's Lexus RX300 does same or better. You are greatly underestimating good synthetic oil capabilities.
Also, Amsoil is the only one that guarantees 25 000 miles.
Don't worry about dumm light.
ukrkoz is offline   Reply With Quote
Old 09-16-2013, 07:45 PM   #6
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
The change oil light is pretty good these days but still does not actually check the oil condition. It's purely based on driving conditions such as warm up times, stop and go vs. highway driving, etc. By resetting it you told it you did an oil change.
I had a Honda Civic that did 100% highway driving 60 each every day. My oil change interval was over 10k miles and did not need to add oil between the change intervals. If you go that far check the oil level every 1000 miles or so to make sure you're not running low. Which synthetic are you using?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-21-2013, 04:03 AM   #7
Rewards Points: 1,062
synth can go to 12-15,000 miles. Up to about 1 year. BMW is ok with this schedule. I am too.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 09-21-2013, 06:03 AM   #8
Rewards Points: 254
If you go extended mileage just make sure yo use an extended mileage filter. Cheap filters plug up and fall apart inside and just run through the bypass. And be sure to check your oil it will use some oil as it ages.
cjm94 is offline   Reply With Quote
Old 09-21-2013, 07:43 AM   #9
12-15 thousand miles in one year would be awesome. I put 15,000 miles on in less than 6 weeks.
Old 09-21-2013, 08:09 AM   #10
PoleCat's Avatar
Rewards Points: 1,652
Engine oil can be a critical factor in extreme operations such as racing but has very little impact on regular day to day use toward performance or longevity. The only valid reason to ever change your oil is to remove contaminants that have built up. Paying a fortune for the best oil on the market then dumping it out is silly. Sure the oil may be guaranteed for 25000 miles but you can't leave all that contamination in there that long...can you?
I use what ever is on sale and change it when it gets dirty. Miles and months are not part of the equation.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following 2 Users Say Thank You to PoleCat For This Useful Post:
cjm94 (09-21-2013), rusty baker (09-21-2013)
Old 09-21-2013, 04:48 PM   #11
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
I'm going to pretend I didn't read this...
Mort is online now   Reply With Quote
Old 09-21-2013, 04:52 PM   #12
I was thinking the same thing! I just didn't want to be rude. Cheap engine oil isn't the same as good engine oil. Polecat's not too bright.
Old 09-21-2013, 04:54 PM   #13
Mort's Avatar
Rewards Points: 694
Oh believe me, what I replied with was the LEAST rude thing I was thinking.
Old 10-02-2013, 03:40 PM   #14
Ok, I had an engine oil analysis done after 10,000 miles and I had very low insoluble count, viscosity was the same as I originally put in, no fuel contamination, and good air and oil filtration. They recommended I go 15,000 miles on the next change and then test again.
Old 10-04-2013, 05:22 PM   #15
Most of what polecat said is true. One thing he said I wouldnt do: buy whatever is on "sale". You have to pay attention to the grade of oil you buy, Pole!! otherwise, your points have merit. Look for the latest/highest API rating. Brands dont matter. Specifications do.
Oil analysis? I was gonna say dont waster youre $$.
And the 25,000 mile guarantee? Marketing, people. Cheap guarantee. How would one dispute that? Evidence would be hard to present in court. Pure marketing gimmick- dont fall for it.
