Switchboard Installation - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-08-2011, 07:27 AM   #1
Gaz
Switchboard installation
Hello,
I have a small switchboard that I want to install into my boat and run it with a car battery. I'm not sure what go's where, I have attached two photos of the switchboard. I plan to run a light, bilge pump my nav lights.
Can anyone help me out?
Gaz is offline   Reply With Quote
Old 02-08-2011, 11:38 AM   #2
Rewards Points: 78
The power from the battery goes to the single terminal at the top, and the 3 wires at the bottom feed the individual circuits. But first, you need check that it is rated for marine use, and that its' ampacity, per circuit and combined, is sufficient for the devices that it will supply.
Old 02-08-2011, 03:48 PM   #3
Gaz
Thanks for your reply,
I bought the switchboard from a boat supply shop and as for the amps it is all sufficient.
I'm assuming positive would go to the top terminal but what about negative?
Old 02-08-2011, 04:34 PM   #4
Rewards Points: 78
Yes, the positive lead from the battery goes to the top lead on the board, the negative terminal or ground on each device goes back the negative terminal of the battery, and none of these terminals should come in contact with any component of your boat.
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 11:36 AM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 05:56 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
