Suzuki Atv Leaks Gas Form Carb - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-13-2009, 11:36 PM   #1
Rick
Suzuki atv leaks gas form carb
My sons atv leaks gas out the overflow tube when he starts it up. Anyone have any ideas what I should check or what should be done. It just started out of the blue one day when he was riding it. Been told it could be the floats. How do I know if the floats are bad? What checks do I do to find the problem? We took it apart and cleaned it with carb cleaner and put it back on and it still leaks but not as bad.
lemoncoke is offline   Reply With Quote
Old 05-17-2009, 12:03 AM   #2
HVAC / Plumbing
if it's from the over flow tube .. I would suspect gas isn't shutting off in the carb & the bowl overfilling with gas. Needle /seat/float/ adjustment to float
kenmac is offline   Reply With Quote
Old 12-28-2010, 09:54 PM   #3
i have a 2009 suzuki kingquad. it would run bout 62 to 65 to scared to hold it past 62mph.now it will only run 50 an it sounds like it has it is missing.i cleaned gas line and throtle body and changed sock on fuel pump.i cant figure it out.ther is a part under seat called afuel cut sesor assy. the top was busted and i dont know how long it was like that.do u think that maybey it is the problem?
rpself is offline   Reply With Quote
Need Solution to Leaks on Metal Roof Flavio Roofing/Siding 13 11-28-2008 03:45 PM
Concrete Form Gap Question bjones Building & Construction 1 03-10-2008 07:32 PM
Murray Snowblower - Carb Problems? bob6831 General DIY Discussions 7 01-15-2007 11:08 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
