Subaru Hood Latch Release ?? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-19-2009, 08:07 PM   #1
Subaru hood latch release ??
when the hood release cable breaks, how in the world does one open the hood ??
andyslater is offline   Reply With Quote
Old 07-19-2009, 08:50 PM   #2
Find a car just like yours, inspect the mechanism, fashion some kind of hook or tool out of coat hanger wire that works on that car, climb under your own car and try, try again.
I'm not very impressed with our '04 Subaru.
Old 07-19-2009, 09:05 PM   #3
Thank you, I have been under, over, and around. Drilled , pried, spied - there has to be a trick. Mine is a 92 I've had since new . I live in the mountains and really like 4 wd, of course I can take mine out of 4w - a good thing...........Andy
Old 07-20-2009, 07:22 PM   #4
Household Handyman
Rewards Points: 1,408
Actually Yoyizit, is right. Your hood latch can be released by using some type of wire, clothes hanger, welding rod, something similar that you can reach in under the lip of the hood to catch the hood latch and pull it open. I've had to do this many times at my cousins shop and at my friends auto parts store for customers. I didn't say it was easy, but it can be done. WHEN you do get it open, attach something to the hood latch THEN, you can reach from outside the hood area, so that you can open the hood until you can fix it for good. Good Luck, David
Old 07-22-2009, 10:21 PM   #5
Thanks, I solved the problem with a sawsall and a cutting torch - the hood now opens easily.
Old 07-23-2009, 12:16 PM   #6
The Nuclear Option
Old 08-05-2009, 11:06 AM   #7
here is a pretty good site for all your DIY subaru needs:
http://www.ultimatesubaru.org/forum/index.php
gregdonovan is offline   Reply With Quote
range hood through the wall - - -stud in the way pacifier1er Building & Construction 30 05-21-2013 09:23 AM
suggestions on contructing a range hood steve1234 Carpentry 15 08-30-2010 10:35 PM
Range Hood Duct Size BOUTYM Appliances 2 12-20-2008 06:34 AM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 04:06 PM
