-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Stumbling start (http://www.diychatroom.com/f46/stumbling-start-122972/)
Bigplanz 11-10-2011 07:43 AM
Stumbling start
38 Attachment(s)
91 Olds Silhouette, 3.1 V6. On start, hot or cold, the engine stumbles @ 400 rpm and dies. Restart and goose the gas pedal and it catches and idles @ 1500 rpm, dropping to 900 rpm after about 30 seconds. Put it in gear it runs fine. Plugs & wires replaced this summer. Cap & rotor replaced in '09.
What do think I should check? I am guessing the thermac intake system has a component either stuck or sticking. I will try spraying some PB blaster on the damper in the snorkel.
Any suggestions/ideas? Thanks.
polarzak 11-10-2011 10:31 AM
If that car has a heat riser valve in the exhaust, I would check to see if it is working properly.
Master of Cold 11-10-2011 10:43 AM
I would start with the idle air control motor.
Master of Cold 11-10-2011 10:46 AM
Also make sure the throttle body is clean, and free of carbon build-up
cjm94 11-10-2011 12:56 PM
Pull the vacuum line off the fuel pressure regulator and see if there is any fuel they are very common to go bad and leak causing a hard start fouling the plugs a little.
D-rock 11-10-2011 03:12 PM
Check vacuum lines, probably all old, dried, and cracked
johnniebravo 11-13-2011 08:51 AM
Had that same motor in an 89 cutlass supreme and had similar problems. My problem ended up being the fuel pressure regulator.
Thurman 11-13-2011 11:19 AM
Fuel pressure regulator common problem with this motor. Do Not put PB Blaster into the intake system. Use a good "throttle body cleaner" to spray into the intake system after you do get it running and up to operating temp. The throttle body will get a coating around the outer edges over time and mileage causing the "butter-fly" of the throttle body to not close completely at idle. This sends a false message to the ECU and could lead to a "stumbling" problem.
Bigplanz 11-13-2011 05:54 PM
38 Attachment(s)
Vacuum lines were ok. Air filter needs to be replaced. Underside or the air intake cover was wet with gas. Fuel pressure issue is a distinct possibility as it sounds/acts like it is starved for gas. I will pick up some throttle body cleaner tomorrow.
reelangler 11-17-2011 10:48 PM
Check vaccum lines, fuel pressure regulator, and did you gap your plugs?
Bigplanz 11-19-2011 08:41 AM
38 Attachment(s)
Vacuum lines were ok. I did gap the plugs to spec. I suspect a dirty IAC valve or throttle body. The issue disappeared on it's own for now. It'll be back of course.
reelangler 11-19-2011 09:21 PM
Does it sit alot?
Bigplanz 11-20-2011 03:37 PM
38 Attachment(s)
Runs every day. Short strips though. Nothing over 10 miles total in a day.
Marty1Mc 11-25-2011 12:26 PM
I would check the FPR, temp sensor, and throttle position sensor.
