#1 |
Stuck cd
I put a CD in the CD player on my 1995 98 Olds and not only will it not play, but it is stuck inside there. Any help would be appreciated! Tried pushing eject but no good.
#2 |
Stuck cd
try pulling CD fuse out for few minutes. some say it worked for them.
#3 |
Stuck cd
Hopefully someone will have an easy solution for you, ROBBYT3, but the only way I have ever gotten a stuck CD out was to remove the player and dismantle it. Drastic, but comparatively easy compared to some the stuff I have done.
#4 |
Stuck cd
Mine has a CD player behind the faceplate (which hinges down to put in a CD). Mine has that tiny hole you see on CD players on PCs, where if you unfold a paper clip, stick it in that hole and give it a solid push, the CD comes out a bit. I have never had to use the one in my car, but have had to do it numerous times on PCs! It's worth a shot to see if your car has one of those. If not, polarzak is probably right, you will need to remove the unit, take it apart, gingerly remove the CD.
#5 |
Stuck cd
Hmmm, I'm wondering if any of these ideas might work on an 8-track.
| Display Modes | |
| Stuck pella window | huai | Windows and Doors | 6 | 04-06-2012 04:22 PM |
| Toilet camera stuck 25 feet underground. | theglove89 | Plumbing | 22 | 08-07-2011 07:48 AM |
| Replacing window sill, but now it's stuck. | rosemonster | Carpentry | 25 | 01-25-2011 05:31 AM |
| Stuck Snake | frederick70 | Plumbing | 22 | 05-13-2009 06:01 PM |
| Vinyl window stuck in wood frame | rlcarter | Remodeling | 7 | 09-26-2007 06:29 PM |
