Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-06-2007, 03:17 PM   #1
stratus died
i have a 200 dodge stratus. i was driving and all of a sudden, check engine light can on and it stop running. is it the timing belt or ....
REBILL is offline   Reply With Quote
Old 12-11-2007, 07:38 PM   #2
stratus died
Have you checked the oil level?
If you try to start it does it turn over?
How many miles on the car?
redline is offline   Reply With Quote
Old 12-14-2007, 09:19 PM   #3
stratus died
i have a 2000 dodge stratus, put new timing belt on, line up all timing mark, will turn over. do i need to take head off . oil fine 158.000mile
Old 12-17-2007, 12:21 PM   #4
47_47's Avatar
stratus died
I would do a compression check on the cylinders. Most newer engines are interference, belt breaks, skip a tooth, bent valves.
47_47 is offline   Reply With Quote
Old 12-17-2007, 01:18 PM   #5
Oldguy
Rehabber's Avatar
stratus died
An auto parts house can look up this particular engine in a Gates belt catalog to see if this engine is a 'free spinner' or an interference engine.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
