Stick Vs Automatic - Automotive Repairs - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-19-2013, 03:13 PM   #31
raylo32's Avatar
Rewards Points: 1,294
Really depends on your preference. As a reference point I have friends that run a horsey business who have had an F-350 power stroke turbo diesel for 5 years or so that they use to pull up to 8 (or 10?) horses at a time. It is an automatic. They had an F-250 version of same for many years prior to this one and never had many repairs except when she put gasoline in the tank. Oops! Tough as nails, which as a Chevy guy is *really* hard for me to say!
Originally Posted by bostonwindows30 View Post
What about a manual truck?? Is this better or worse, for towing???
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 08-19-2013, 04:20 PM   #32
I have a 96 f150 v8 with a manual. IMO a manual transmission will outlast an automatic, less moving parts. I hate these 8 speed automatics they put in cars they won't last long at all, all for gas mileage.
dvatt is offline   Reply With Quote
Old 08-19-2013, 05:18 PM   #33
Rewards Points: 1,062
OK- yes, parts CAN wear on a MT, but guys, throw out bearings and even a new clutch?? There is no comparison to these low cost fixes, both which can be fixed by a DIY (not usualy so with AT's). Also, the key thing is that when/as these 2 wearable parts wear/become old. you have ample, ample, ample time to repair it- schedule the right time. Not so with an AT. It can go anywhere- thats the big gripe with me on AT's.
When an AT goes, its $2000-5000. Clutch on a MT- $600 , and while its out they pop in a new T.O. bearing for an extra $15. No comparison. One's a thunderstorm, the other is a hurricane.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 08-19-2013, 05:20 PM   #34
Rewards Points: 164
Lol gotcha
bostonwindows30 is offline   Reply With Quote
Old 08-20-2013, 02:12 AM   #35
Rewards Points: 164
Now that we got the transmission out of the way, what about the difference between f150 and 250 I know it's the engine, but what else comes into play??? Help
Old 08-20-2013, 06:44 AM   #36
Still Decompressing
Rewards Points: 273
the f250 also has upgraded suspension and brakes. You may also find an upgraded interrior package on the 250
caveeagle is offline   Reply With Quote
Old 08-20-2013, 06:49 AM   #37
Ole Wood Worker
BigJim's Avatar
Rewards Points: 776
And rear end.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-20-2013, 07:31 AM   #38
Rewards Points: 164
I want the power if a chevy 350 what in the ford line is close to that??
Old 08-21-2013, 08:06 PM   #39
Rewards Points: 164
What's better 4 apples or 5 ???
Old 08-21-2013, 10:07 PM   #40
Rewards Points: 131
a manual will most likely outlast an auto, but not due to the moving parts. if anything, a manual has more moving parts than an auto, at best, the same. the biggest difference being - a dried up gnat turd in an auto could destroy it. the same piece of insect fecal matter in a manual would be pulverized into oblivion between two chromemoly gears.
all transmissions, manual or auto, have their own inherent strengths and weaknesses. OP - you'd be better served perusing message boards that cater to the vintage of the truck youre looking to buy, and see what those owners say about each transmission.
Chokingdogs is offline   Reply With Quote
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
self stick vinyl tiles frank10 Flooring 1 03-27-2013 10:36 AM
Trying to install self stick vinyl tile on ceiling but it doesn't stick buggy Tiling, ceramics, marble 2 01-27-2012 05:50 PM
Peel and stick on painted concrete? polarzak Flooring 8 12-23-2011 01:13 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 07:52 AM
