Stick Vs Automatic - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-17-2013, 08:15 PM   #16
Rewards Points: 164
Okay now that have have that info what about a ford pick up love the older bodies late 80's looking at three of them some are straight 6 and then there's a few with 302's ??? Thought???
bostonwindows30 is offline   Reply With Quote
Old 08-17-2013, 08:59 PM   #17
747
registered
747's Avatar
Rewards Points: 534
It depends on where you located. Alot of stoplights and traffic automatic. If not... Price would dictate.
747 is offline   Reply With Quote
Old 08-17-2013, 09:24 PM   #18
The 6 is within 3 cubic inches of the V-8. It has mire more torque, and you'll get better mileage with the 6.
That being said, the 6 has had high mileage problems with rod knocking...and you'll want to block off the EGR, or put a piece of sheet metal in there with a small hole much improves driveability.
If it had the 5-speed manual: it's a Mazda sourced unit. The transmissions are very reliable, but have had problems leaking top coves, and worn shift forks.
The good news is that you cab pull back the carpet or rubber floor mat, and fix all those problems inside the truck cab.
If you do that, take the top cover to a trans shop. Have them seal the leaking ports, replace the fork, and replace the bushings in the shifter.
It'll shift then like a brand new truck. Before you reattach the top cover, fill it with new Mercon ATF (that's what the manual trans uses (the F-150 5- speed) from that era.
RoyalAcresRod is offline   Reply With Quote
Old 08-18-2013, 03:43 AM   #19
Rewards Points: 164
Thank you royal awesome info
Old 08-18-2013, 07:50 AM   #20
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,086
That is some insider information right there from someone that has turned wrenches on a just a few of them.
Old 08-18-2013, 07:57 AM   #21
Rewards Points: 736
If things like "too many traffic lights" even enter your brain, a manual just isn't for you. If you drive them enough, they should be second nature, unless you have arthritis in your left leg or something. I sit in traffic a lot, I don't really notice the shifting part.
I DO notice when I'm driving an auto and can't merge onto the highway cuz the stupid things won't shift. I'll always have a manual on my CAR as long as they still keep making them.
THAT SAID, for a truck? Especially one with plenty of engine? Meh. I like having stick for the control it gives you over an engine that might otherwise be lacking, so a truck with a larger engine? I'd be fine with auto.
TheBobmanNH is offline   Reply With Quote
Old 08-18-2013, 12:06 PM   #22
Rewards Points: 1,062
Originally Posted by ukrkoz View Post
Much less hassle with manual. More reliable. Much easier to repair. Under proper maintenance, they will overlast any automatic. More fun to drive. Much easier on repairs. Overall vehicle lighter weight=better mpg. Manual will still outperform automatic on mpg.
You eventually get tired of shifting.
Getting stuck, UPHILL, in stop and go traffic is a challenge.
Stopping at red light, on a 15% uphill, winter time, well......
Right. Whoever said an AT will outlast a manual - not accurate information. yes, if you grind gears/actually grinding synchros, not gears, burn out the clutch/ride the clutch (a family member of mine does that- when I pointed it out to him he said "who cares")- you will destroy your manual trans in <30,000 miles. yet, if you hammer the gas pedal at every green light, or procrastinate on changing AT fluid (a tedious and expensive maintenence)your AT will not last.
Also, Do you trust that auto to not break unexpectedly?? If so, you do not understand auto trannys. I will never trust ANY AT driving anywhere, especially with family, on a long trip. It is the second most expensive device to repair in any motor vehicle. Why gamble.
resale value?? Thats a joke. First, MT's are cheaper to begin with. Does anyone expect to gain monetary value when one spent less on that vehicle in the first place? isnt that concept get something for nothing?
The only disadvantage a MT has is in stop/go traffic- thats it. an AT wil be nicer to your left calf muscle........
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 08-18-2013, 12:19 PM   #23
Rewards Points: 164
Lol right on, I like manuals there fun.. And cheaper to fix..
Old 08-19-2013, 05:52 AM   #24
DIY staff
Rewards Points: 7,174
I always loved a manual trans----
As the only 'odd ball' with a manual, I have had the pleasure of teaching many people how to use a clutch----
If any of you ever taught a new driver how to shift,you know the feeling----listening to your car being abused by a nervous newbie as they figure out how to start and stop---
The easiest student was a young female friend---The parking lot I chose was covered with an inch of snow---so the wheels would spin instead of stalling the engine----She was shifting like a pro in no time----Mike---
Old 08-19-2013, 07:37 AM   #25
Rewards Points: 164
Lol they are fun..
Old 08-19-2013, 09:12 AM   #26
Still Decompressing
Rewards Points: 273
I have always generally preferred Manuals. The 6-speed in my '04 mustang (cobra) is what sealed the deal when I bought it back in 04.
Having said that.... They both have there place, and their own pros/cons.
A manual tranny won't (typically) be cheaper if you don't drive it correctly. Most TO bearing are killed by drivers 'riding' the clutch, leaving their left foot resting on the pedal. This causes constant spinning of the TO bearing, which WILL wear it out. Also clutch abuse, slipping and burning the clutch will give you bad results in the long turn.
Generally, I think MTs are more straight fwd and easier to understand.
Somebody made a comment about fuel econemy. Very hard to compare apples-to-apples. Most cars have different gearing for auto vs manual models, and many people don't know how to drive a MT properly. Hot Dog around and spin the RPM up to redline at every light, and ....NO, you wont get decent mileage. Most modern electronic trannys actually 'lock' up input/output shafts when you are in highway cruising mode. So none of the old school slippage and much less parasitic loss. BUT..... You are still spinning a torque converter, T-fluid pump, and dragging about 70-100 lb of extra weight. So, when you consider all factors, there is really NO WAY an auto tranny can give you better mileage in a true heads-up comparison.
I really HATE auto trannys in used cars. You have NO idea how its been treated, and how long it will last. And they can be VERY expensive to replace.
caveeagle is offline   Reply With Quote
Old 08-19-2013, 11:01 AM   #27
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
Unrelated to this thread...but a true story....
A few years ago I rolled up on an armed robbery in progress....I just happened to be in the same area as the get-away car....guys came around the corner....saw me....said "oh sh!t"...and went the other way...because of traffic, it took me a min to get around to the other side...what I found out was that two of them tried to carjack a couple of cars in the parking lot...both had sticks.....the numb nuts couldn't drive a manual....
I caught two of them a short time later in a wash...the dog found the 3rd one in a nursery.....the hard way.....I've never seen a happier dog....they guy was hurting....I guess he didn't believe them when they told him to come out or the dog would bite him....
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (08-19-2013)
Old 08-19-2013, 12:03 PM   #28
raylo32's Avatar
Rewards Points: 1,252
We went on a trip to France back in May and of course I had to check out the cars. There were *very* few trucks and SUVs, really almost non-existent. And you could walk for blocks looking into the cars before you'd spot one with an automatic. Those are the oddballs over there. Probably about a third to half of the cars were diesels, too.
I love the 6-speed manual in my Camaro... with its seriously overdrive ratio in 6th you are doing 84 mph @ 2000 rpm :-). Bullet proof so far at 110k miles. But I have an auto in my daily driver Toyota Tacoma. Too much traffic here to deal with a manual on a daily basis. Its 5-speed auto feels very solid, although I haven't towed anything with it.
----Mike---
Live long and prosper.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
Old 08-19-2013, 02:25 PM   #29
Rewards Points: 164
What about a manual truck?? Is this better or worse, for towing???
Old 08-19-2013, 02:48 PM   #30
Rewards Points: 164
Lol lol lol awesome guys...
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
self stick vinyl tiles frank10 Flooring 1 03-27-2013 10:36 AM
Trying to install self stick vinyl tile on ceiling but it doesn't stick buggy Tiling, ceramics, marble 2 01-27-2012 05:50 PM
Peel and stick on painted concrete? polarzak Flooring 8 12-23-2011 01:13 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 07:52 AM
