Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-28-2012, 01:25 AM   #1
Still Learning
Starting problems!!!
hey guys. I gave a dude a jump start and when he took the cables off his car he touched the two cables together and something got fried. Now my truck won't turn over. It just clicks when I try to turn it over. Any ideas on what I should take a look at? I don't even know where to start...
thehvacguy is offline   Reply With Quote
Old 09-28-2012, 01:39 AM   #2
DIY Enthusiast
sublime2's Avatar
Did you try hooking cables back up to HIS running truck and starting yours.
The clicking usually means the battery dose not have enough power to crank. Make sure YOUR terminals are clean and tightly secured to the battery.
sublime2 is offline   Reply With Quote
Old 09-28-2012, 02:01 AM   #3
Still Learning
I took the battery to autozone any they charged it up for me but its not holding a charge. I'm hoping I didn't fry the alternator...
Old 09-28-2012, 02:11 AM   #4
DIY Enthusiast
sublime2's Avatar
Alternator runs all electric once the car is started along with recharging the battery.
It does not start the car. Your battery is dead,put a new one in and try it. Normally you can start your car and disconnect the battery and the car will continue to run,because it runs off of the alternator.
Old 09-28-2012, 09:15 AM   #5
silver_flash's Avatar
the battery is losing its charge while in your truck
silver_flash is offline   Reply With Quote
Old 09-28-2012, 09:16 AM   #6
Old 09-28-2012, 09:17 AM   #7
I had this same problem once. but it was a loose connection on the negative battery terminal. it drains the battery. what year and make is your truck?
Old 09-28-2012, 09:34 AM   #8
the selenide on the starter or the starter itself might be bad. have to jump the solenoid to find out what is broke.
Old 09-28-2012, 11:03 AM   #9
Sounds like he fried your battery.
Were the jumpers connected to both terminals on your battery? Or just the positive to your battery and the negative was connected to a body ground on your vehicle? If the latter, check your vehicle ground wires to see if those were fried.
I hope this guy pays for the damage he did!
Billy_Bob is offline   Reply With Quote
Old 09-28-2012, 03:31 PM   #10
Whats the year and make if the truck. A lot of new models have a main fuse that may be blown.
cjm94 is offline   Reply With Quote
Old 09-28-2012, 07:14 PM   #11
thats what I was thinking too!!
D-rock is offline   Reply With Quote
Old 10-11-2012, 12:03 PM   #12
Also. Don't disconnect the battery while the vehicle is running. This can result in a fried ecu in newer cars.
biggs9599 is offline   Reply With Quote
The Following User Says Thank You to biggs9599 For This Useful Post:
cjm94 (10-11-2012)
Old 10-17-2012, 10:59 PM   #13
I was going to suggest this as well. That's an old way to check things.
Carkid0007 is offline   Reply With Quote
97 acura 3.2 TL with multiple problems vonbismarck Automotive Repairs 5 02-14-2012 12:00 AM
how to build a single phase induction motor sashman Electrical 3 03-31-2011 08:18 AM
Timecutter 16:42z trouble starting and now stopped starting jackdoldno7 Landscaping & Lawn Care 0 09-10-2010 12:43 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
