-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Starting Issues (http://www.diychatroom.com/f46/starting-issues-44596/)
77CJ5 05-16-2009 01:46 PM
Starting Issues
Greetings...
I have a 1977 CJ5. It will not start. Was running fine, now won't start. New coil, distrbuter, rotor, cap, wires, plugs, ignition module, fule filter, fule pump, air filter. I can smell gas (rather strong gas odor). Seems like it is flooding or not getting fire...thoughts?
nap 05-16-2009 02:20 PM
was it just as simple as:
I'm driving, I parked for the night and then, I want to go to the store and nothing.
or were there some signs of a problem?
When you crank it, does it sound as it always has? Does it spin faster than before? a strained attempt followed by normal cranking and then back to the strained attempt?
77CJ5 05-16-2009 02:32 PM
No signs of anything going wrong. Was running fine, sat for a week or two and now will not start. Sounds 'normal" while trying to start.
nap 05-16-2009 05:15 PM
if it is humid in your area and gets cool at night or you off road through water, I would suspect the possibility of moisture under the dist cap.
I would start with removing the cap, drying it and then letting it air dry while using a hair dryer on the internal components of the dist to dry them. Be careful to not cause a fire with any gas and the heating element of the dryer.
frazierdavidson 05-16-2009 07:13 PM
Timing chain could have possibly jumped a couple of teeth. I would bring #1 cylinder up to top dead center on compression stroke and check the position of the rotor on the distributor. I have ssen it happen when you shut the car off and try to restart.
nap 05-16-2009 10:19 PM
that is why I asked the questions I did in my first post. I was thinking the possibility of the same thing. A timing chain slip almost always causes the engine to crank differently than "normal" due to the changes in compression from when it is in time. Always something to look at though. I can usually tell by the sounds but if you are not familiar with what you are listening for, it can be easily missed.
