Starting Issues - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-02-2015, 04:55 PM   #1
Rewards Points: 117
Starting issues
I have a ford e350 van.
Sometimes the vehicle will not start in park..I turn the key, place it in neutral and the vehicle starts.
Can someone please explain.
mustang64 is offline   Reply With Quote
Old 11-02-2015, 06:28 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,596
Check the gear shift interlock.
There should be a sensor that indicates when the vehicle is in park.
Old 11-02-2015, 06:29 PM   #3
Rewards Points: 117
Where would that be located??
Old 11-02-2015, 07:15 PM   #4
Rewards Points: 254
The transmission range position sensor on the transmission at shift linkage
cjm94 is offline   Reply With Quote
The Following User Says Thank You to cjm94 For This Useful Post:
Windows on Wash (11-02-2015)
Old 11-02-2015, 07:59 PM   #5
Rewards Points: 117
Can you please explain that location.
Old 11-02-2015, 08:30 PM   #6
Rewards Points: 254
On the side of the transmission where the shift cable is attached. Also make sure you do not have a lot of slop in the shift linkage in the steering column, that is a common cause of this concern.
Old 11-02-2015, 09:06 PM   #7
Rewards Points: 117
How do I adjust the slop in the shift linkage??
Old 11-02-2015, 09:21 PM   #8
Rewards Points: 254
Tighten any loose bolts or replace worn bushings on shifter shaft
Old 11-02-2015, 10:00 PM   #9
Rewards Points: 117
I'll try it out.
Thanks.
Sealing septic tank lid...Issues? MANGINA Plumbing 11 01-16-2016 11:05 AM
starting issues sammy37 HVAC 6 04-08-2013 03:23 PM
Preparing 1st step for over-the-post starting newel hkeiner Carpentry 9 03-18-2013 12:02 PM
Can starting step tread be 3/4" deeper than other treads? hkeiner Carpentry 8 02-18-2013 10:24 PM
Timecutter 16:42z trouble starting and now stopped starting jackdoldno7 Landscaping & Lawn Care 0 09-10-2010 11:43 AM
