Starter Going Bad? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-03-2007, 12:00 AM   #1
Rewards Points: 123
Starter going bad?
My station car has been experiencing a problem lately. When I attempt to start it sometimes it does nothing. Today I was able to reproduce this behavior multiple times. I tried starting it multiple times over and over and out of the 6 times I tried at least 4 times when turning the ignition I got total silence. Is this a sign of a failing starter? My lights and wipers worked fine so I guess the battery is ok.
jerome8283 is offline   Reply With Quote
Old 04-03-2007, 06:31 AM   #2
Master Craftsman
Big Dave's Avatar
It's hard to say. I had a truck that had two hot terminals coming off of the battery. One went to the starter directly and the other powered the rest of the acc. THe wipers, horn, lights, etc would work but it would not start until you wiggled the power cable. You might see if that's the problem.
Typically when the starter starts to go bad you will at least hear a clicking sound coming from it when you turn the key.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 04-03-2007, 11:40 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
Could be a loose/corroded wiring issue (battery wires a strong candidate)
Often enough juice to run small items works OK, but the big jolt for the starter causes too much juice for the "iffy" connection to handle
slickshift is offline   Reply With Quote
Old 04-05-2007, 04:49 PM   #4
Rewards Points: 123
I took the car to my local shop and was told the starter contacts need replacing, $256 bucks
fix my Lawn Mower Starter myself !!! KUIPORNG Landscaping & Lawn Care 10 06-28-2009 02:34 PM
replacing starter boards Bob C Roofing/Siding 6 07-17-2007 01:04 PM
CertainTeed starter shingle ? MACCC Roofing/Siding 2 04-20-2007 03:26 PM
No starter strips fishwi Roofing/Siding 4 10-12-2005 10:32 AM
No starter strip!?! hockeyhead Roofing/Siding 10 09-17-2005 12:54 PM
