-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   squeeky pulley or belt (http://www.diychatroom.com/f46/squeeky-pulley-belt-176082/)
thehvacguy 04-01-2013 11:42 PM
I'm not sure what's really goin on but something is squeeking under the hood. The sound is coming from near the alternator but the tensioner pulley is right under it. How do I know which one it is? The car is a 91 dodge dynasty
joecaption 04-02-2013 06:28 AM
Got a long bladed screwdriver?
Use it like a stethoscope.
When the last time you replaced the belt?
64pvolvo1800 04-02-2013 07:46 AM
Take the belt loose and spin each pulley to identify any noisy or wobbly ones. Run the engine for a few minutes first and also check for any temperature deviations on each pulley. IF the engine has a timing belt as well, then I would run it without the steering/alternator/ac belt briefly to see if the noise continued. If so, bad news. It's in the timing belt pulleys and you need experience to solve that.
thehvacguy 04-02-2013 08:37 AM
I just bought the car yesterday for $400 cause I don't feel like dropping an engine in my truck just yet :)
ukrkoz 04-02-2013 08:58 PM
Well, not sure on screwdriver, but a long piece of garden hose does make excellent stethoscope. Also, belts normally do not squeek with engine at idle. They do under tension, at start ups and load. Likely pulley. So - hose it is. Or, if you feel lucky, a screwdriver.
sam floor 04-02-2013 09:06 PM
Have used a screwdriver for 50 years.
Thurman 04-03-2013 08:55 PM
With the engine OFF and the key OUT, try this: Get a bar of "Lava" branded soap. Rub this Lava soap onto the inside of the serpentine belt everywhere you can get to it. Then start the engine and let it run a few minutes. IF the squeak stops, or is not as bad, you most likely have a belt that needs to be replaced.
Metro 04-04-2013 12:51 PM
You can always tell how well a car has been maintained by how clean it is under the hood. What does yours look like? If it looks like indifferent maintenance through the years, perform all the routine tasks and clean it up really good. It might be something as simple as that.
paintdrying 04-07-2013 10:18 PM
so it is squaking. That is terrible. Pop the hood and spray part by part with a hose. If it changes then you have an idea bearing or belt. If you were to lazy to fix your truck, I do not see you pulling the belt like Volvo mentions. I have a broom stick I use to listen to cars, I had a heater off blow off in my face and never put my face to close to an engine
thehvacguy 04-18-2013 01:11 AM
You arrogant bastard! I love my truck and I poured my heart and soul into big bertha. I bought it from a tweaker and replaced EVERYTHING under the hood except for the engine. Now I'm driving some piece of **** car with the window that fell off into the door. Every Damn Gasket is leaking oil and if I drive it to the point that the engine gets warm it starts smoking from the oil burning on the exhaust manifold. This is a front wheel drive vehicle and I'm not a mechanic. I do HVAC and plumbing 60 hours a week so before you call me lazy again you can go shuv a pain roller up your Ass and watch paint dry you prick
