Spot Lamps - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-15-2007, 03:29 AM   #1
Spot Lamps
I have two 55w spots on the front of my car, I would like to rewire them so they sit on reduced power like a side light when not on main beam. Do I use a resistor in series/parallel and if so what size?
Cheers.
wesser is offline   Reply With Quote
Old 02-19-2007, 01:03 PM   #2
Tom
Send a message via AIM to tvlfleming
does your vehicle have daytime running lights? Either running lights or headlights come on with ignition?
tvlfleming is offline   Reply With Quote
Old 02-19-2007, 07:13 PM   #3
Rewards Points: 150
good 'ol ohm's law...
wattage = current * voltage
Voltage = current * resistance
cars are 12vdc.
current (amps) is dependant on the load (resistance) so you can't change that directly
all you can really do is play with the resistance values (load 'er down to reduce current!)
so, 55W lights will draw 4.5 amps, and be a 2.6ohm load.
You can play with the figures and sub them back into the two above equations and recalculate current, wattage, and resistance.
your resistor will have to be a big one, that sucker will get red hot too... again, just use ohms law. once you figure out what resistance you need, you'll have to determine the power it can take before it burns up, which is of course wattage.... current * voltage, its gonna be around 50watts or so...
yes that's a hugggee power rating on a resistor, why? because incadescent light bulbs are a waste! it's pretty much like a dead short, thats why it glows red hot and emits light! something like 90% of the energy turns into heat and is wasted, just 10% or so is visible light
why not just get lower rated bulbs?
(unrelated)....
an x-ray machine is only about 1% efficient in producing x-rays . you don't see many energy-star compliant x-ray machines!
elementx440 is offline   Reply With Quote
Old 02-20-2007, 03:16 AM   #4
Thanks for you help - You know what it's like I got an Idea but it sounds like it's not worth the trouble.
Cheers.
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 02:10 PM
3-way lamps - my headache panoply Electrical 1 04-16-2007 05:32 AM
material for goosneck lamps sweatshirtbrigade Electrical 2 03-11-2007 01:55 PM
Outdoor Post lamps tennisnut Electrical 4 10-16-2006 03:48 PM
Wall lamps and chair rail alvanos Carpentry 1 04-26-2006 12:35 PM
