Spark Plugs Seizing On High Mileage Engines:myth Or Fact? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-10-2012, 10:52 AM   #1
I had no problem removing all six spark plugs from the 3.1 v-6 ( 1999chevy lumina 96,000 miles) despite my mechanic friend telling me I'm opening Pandora's box and some plugs may be seized in the aluminum head. I purchased Crc freeze off and a lisle spark plug thread chaser. I even contemplated using a impact driver. All came out easy w/ a 1/2 drive ratchet. Old plugs had oil on threads(leaking valve covers?) which he says was my saving grace. any thoughts?It's my teenage daughter's car and I want it to be reliable. Some old plugs had the platinum blown off the ground. Electrodes were good yet. Glad I changed them. New wires too. Thexton engine mover made it possible.Did I get lucky?
toolaholic is offline   Reply With Quote
Old 11-10-2012, 02:19 PM   #2
Rewards Points: 1,062
Just what I learned- no reason plugs have to "fuse"/sieze just cuz high mileage. If maintained well (who knows if your previous car owner did) shouldnt be a problem.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 11-10-2012, 02:56 PM   #3
I've seen more spark plug boots/wires coming apart more often then plugs seizing in the heads. If replacing spark plugs I would suggest also doing wires on 100,000 mile service interval engines unless coil over style.
D-rock is offline   Reply With Quote
Old 11-10-2012, 03:10 PM   #4
Yeah I put ac delco professional wires on w/ dielectric grease in the boots.
Old 11-10-2012, 03:46 PM   #5
Rewards Points: 254
The ford 3 valve engines have issues with the plugs breaking off. But most others your more likely too have a plug come loose and blow out than seize in.
cjm94 is offline   Reply With Quote
Old 11-10-2012, 05:09 PM   #6
ukrkoz's Avatar
Rewards Points: 946
1. you did put dab of Antiseize on the threads, right?
2. Your plugs are located in the side wall, going into combustion chambers at slight angle? Correct me if I'm wrong, there should be no head gasket where they at. Where's oil coming from then? Dripping from valve covers down?
ukrkoz is offline   Reply With Quote
Old 11-10-2012, 05:33 PM   #7
Anti seize yes. Maybe plugs replaced before and coated w/ oil to install. I hear this is done. Torqued to 130 inch lbs. spec is 132. Probably a little tighter than factory spec due to anti seize Lubing threads.
Old 11-10-2012, 05:39 PM   #8
Oh and it has the dreaded o ring distributor plug leak. But most oil leak goes toward the back of engine. You are correct as to plug location.
Old 11-10-2012, 08:06 PM   #9
Rewards Points: 54
Happens on certain year model f150's.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 11-10-2012, 11:34 PM   #10
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 92
More common on aluminum heads than the old heads.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-11-2012, 09:24 AM   #11
Rewards Points: 236
yep. those should be removed and cleaned or replaced every 20k or less.
way to go ford.
Fix'n it is offline   Reply With Quote
Old 11-11-2012, 09:27 AM   #12
Rewards Points: 372
way to go ford.
Which is not very likely, since the spark plug change interval on a 5.4L Ford V8 (the ones most affected by this issue), is 100,000 miles.
imautoparts is offline   Reply With Quote
Old 11-11-2012, 09:37 AM   #13
ukrkoz's Avatar
Rewards Points: 946
which he has GM engine, not Ford.
1. so, you have oil getting into chambers from somewhere, and drizzling onto threads. The way they are situated, oil either drips from the top and seeps onto the threads, likely, from valve cover gasket. So scope for those leaks. Or, you have oil getting inside the chambers, and not burnt completely during combustion, and sprayed over threads. Most of a plug is inside sticking out, you have what - maybe 3 full threads in the engine head?
2. yep, heard that too. so this what happens. if you do NOT have continuous lubrication with oil, and put some oil onto plug threads to "lubricate" them, as it gets VERY hot, oil cakes and THAT will definitely bind plug to threads. Done it. That's why they came up with anti seize. Which is, basically, metalized powder in liquid form. Should also be used on lug nuts.
3. what you better off doing now is figuring out where that oil is coming from. As it will keep killing plugs. Or you will have to clean them every so many miles, and by that, you'll screw up plug seats sooner than necessary. Unless they have steel jackets, but somehow I doubt they do, as my 5.3L Vortech doesn't.
Old 11-11-2012, 09:37 AM   #14
Rewards Points: 236
indeed, beause the owners don't know about this issue. UNTIL they get a $800 tune up bill.
Old 11-11-2012, 10:38 AM   #15
Thanks for your informative reply. You are a very knowledgable guy. I researched putting the plugs in and it went fine. Guess I'll look into the oil issues.
Inspecting spark plugs in a high mileage car Bigplanz Automotive Repairs 16 07-18-2011 06:28 AM
'06 Impala - how to change spark plugs + gap spec. DIYguy2000 Automotive Repairs 0 06-20-2011 09:26 AM
Spark Plugs rusty baker Automotive Repairs 13 08-30-2009 08:09 PM
