#1 |
Pro Flooring Installer
Spark Plugs
My father-in-law gave us an 85 Ford van 302 that he bought new. 100,000 miles and he never changed the plugs. Any suggestions for getting them out without breaking them off?
#2 |
Oldguy
Spark Plugs
Tighten them just enough so they move, then remove them. Sounds strange but it works.
If you think you can, or if you think you can't, you're probably right. ASE certified master auto tech, Retired. |
#3 |
It was a dark and stormy
Spark Plugs
Ditto, but you might try penetrating oil first.
#4 |
Spark Plugs
WD 40 or something different?
#5 |
Spark Plugs
WD means Water Displacement but I guess it's OK
http://en.wikipedia.org/wiki/Penetrating_oil Give it >10 min. to soak in, apply it again, then try to free the plugs. It might be easier when the engine is hot, but be careful with aluminum engine blocks. Last edited by Yoyizit; 07-02-2009 at 04:18 PM. |
#6 |
Xtreme DIY'r
Spark Plugs |
#7 |
World's Tallest Midget
Spark Plugs
Those will be iron heads, so you shouldn't have any problems with breaking them. I'd be concerned with the plug wire heads, though, so don't do it without another mode of transportation to get to an auto parts store.
#8 |
Spark Plugs
I'm changing the wires, cap and rotor, too. Parts store is 1/2 block from here. And I also have 3 other vehicles.
#9 | |
Spark PlugsQuote:
With my miss problem I returned my rotor and cap because it turned out new plugs solved it. My wires checked good. Last edited by Yoyizit; 07-04-2009 at 03:00 PM. |
#10 |
(the original)
Spark Plugs
Toss the WD40. SeaFoam Deep Creep is best, Blaster PB runs a pretty close second. At least that's been my experience.
Tighten slightly first, then loosen is good advice |
#11 |
Custom Cabinet Maker
Spark Plugs
I agree with the warm the engine up. Cast iron moves with cold and heat. The heads will expand when warm/hot helping to release the grip on the plug threads. yes on tighten than loosen. I like PB also. wd40 to me anyway is more myth than real use
#12 |
Spark Plugs
Brake fluid works extremely well. Just don't get it on any painted surface.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it. |
#13 |
Spark Plugs |
#14 |
Spark Plugs
Finally got a chance to work on it. They weren't even tight. They just screwed right out.
| Display Modes | |
| Outlet Spark | DIYLI | Electrical | 13 | 06-16-2012 10:08 AM |
| GFCI plugs in kitchen | DeterminedMom | Electrical | 10 | 04-23-2009 11:42 PM |
| KO plugs are dangerous! | KE2KB | Electrical | 10 | 11-25-2008 07:57 PM |
| Surge protector that delays power to certain plugs? | Thresher | Appliances | 2 | 06-24-2008 01:15 PM |
