-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   spark issues (http://www.diychatroom.com/f46/spark-issues-184444/)
CocayneKille 07-29-2013 01:19 PM
spark issues
1987 dodge d150
I have replaced the ignition coil and the spark plugs have been changed, but there is still an intermittent spark problem. This truck won't start, I can crank for over an hour with no signs of ignition. Any suggestion would be greatly appreciated.
CocayneKille 07-29-2013 01:42 PM
Also, what other components contribute to getting electricity to the spark plugs?
toolaholic 07-29-2013 05:58 PM
Spark plug wires, distributor cap and rotor. Stator underneath distributor cap and rotor.
Bigplanz 07-29-2013 06:53 PM
38 Attachment(s)
Is there spark at each plug.
CocayneKille 07-29-2013 10:15 PM
There is no spark at all.
ukrkoz 07-29-2013 11:07 PM
bad dizzy.
bad ECM
bad wires
all of the above.
CocayneKille 07-30-2013 02:21 AM
I don't think that every wire would have spontaneously gone "bad" at the same time.
toolaholic 07-30-2013 09:22 AM
Starter? Ignition module if it has one?
CocayneKille 07-30-2013 09:31 AM
It will crank and crank, but not make a sound like it is trying to fire. Doesn't the cranking mean the starter is working?
CocayneKille 07-30-2013 09:33 AM
Will have to look into the possibility of an ignition module issue, not sure if it has one.
ukrkoz 07-30-2013 11:20 PM
http://www.ifitjams.com/starting.htm
Have at it. You either do not have fuel, or do not have spark, or fuel and spark, or plugs are fouled bad with fuel, result of having too much fuel.
If it cranks, then starter works. I had a car, Eclipse, where all 4 wires went bad.
So if starter works, it's either spark or fuel. Or both, which is ECM. As it controls BOTH.
Follow the flow chart for starters.
ddawg16 07-31-2013 01:15 AM
87? Then it still has a resistor for the ignition....
Back to basics......
Use a voltmeter and measure on the Pos side of the coil. With the ignition on you should have about 12v. If not, start going backwards.
And....tell us what you did before you got the start problem.
BTW....if you can crank for an hour and nothing happens....this is not an intermittent starting problem...this is a NO START problem.
CocayneKille 07-31-2013 01:35 AM
Lol I say this issue is intermittent because everyday it starts. Sometimes it will start with the first or two, other times in the same day it will crank for long periods with no sound like it is trying to fire. Also, I don't believe I mentioned that sometimes it will run fine for the 5 to 10 then it will start having pop back (most irritating when trying to go up a highway hill, no enough constant power to gain any speed while it is popping back)
CocayneKille 07-31-2013 01:46 AM
This truck is fairly new to me, I have not done anything to it that isn't mentioned on here (I don't think I have anyways). The first couple weeks there was no sign of any issues with this truck. Then one day on my lunch break, I get out to the truck and try to start it, did not have any luck for that entire hour. Some days it fires with no sign of an issue, other days, as stated several times now, it doesn't seen to want to fire for extended periods of time. My brother used his spark tester and we have got a definitive answer that, while it is having this issue, there is no spark. I'm 100% convinced that the issue is not fuel related because I have replaced the fuel pump and filter. I have pumped the pedal enough to where I can angel the gas, so I no there is fuel getting to the engine.
CocayneKille 07-31-2013 01:52 AM
If there is something more on the information side that could help you help me diagnose this truck, let me know what else I might be able to provide. Also, if the sentences seem unorganized or incomplete, I blame my phones auto-correct. It is annoying sometimes.
