Snowblower Won't Start!! - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-22-2009, 11:42 AM   #1
Snowblower won't start!!
I have craftsman single stage snowblower. When I push the electric start button, it makes noise but doesn't start. I have replaced the plug but nothing has changed. What should I do next to get it started? Thanks.
didi1020 is offline   Reply With Quote
Old 12-22-2009, 01:55 PM   #2
Dump the old gas and put fresh in. Then before you try it, drain the carb if there is a drain. If there is not a drain, take the gas line off the carb and allow the gas to drain out of the line. Then try it. If that doesn't work, you may have to take the carb apart and clean it. 90% of the time, the reason a motor won't start after sitting is because gas turns to varnish if it sits. And then that varnish clogs jets and orfices inside the carb.
budedm is offline   Reply With Quote
Old 12-22-2009, 02:39 PM   #3
47_47's Avatar
Rewards Points: 50
Does the engine turn over? If not you probably have a bad bendix drive on the starter or a bad spot on the flywheel ring.
47_47 is online now   Reply With Quote
Old 12-22-2009, 03:43 PM   #4
Ditto, depending on what you mean by "noise".
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 08:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 10:58 AM
arien snowblower jimb58 Tools 1 01-14-2009 06:56 PM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 09:21 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 11:39 AM
