Snow Blwer Repair - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-21-2009, 04:46 PM   #1
Snow Blwer Repair
New Snow Blower Owner without a manual! My stepson poured the 2 stroke oil in the tank, then the gas without mixing it. I've drained the tank, mixed the gas and oil and refilled but it still won't start. Any advice?
Goodnite Uncle is offline   Reply With Quote
Old 12-21-2009, 05:33 PM   #2
Landscaper
did your stepsun start it at all?
Is there a prime bulb? (to get the gas to the carb.)
DBRhino is offline   Reply With Quote
Old 12-21-2009, 09:03 PM   #3
An old Tradesmen
Rewards Points: 6,516
Spark plug may be soaked with oil.
Pull and clean it.
Old 12-22-2009, 07:13 AM   #4
47_47's Avatar
Rewards Points: 44
Pull and clean it.
Also check the fuel pick up screen (on the hose in the tank) and fuel filter. These may be saturated with oil, not allowing fuel to flow.
47_47 is offline   Reply With Quote
Old 12-28-2009, 12:10 PM   #5
No, it never started. He drained the tank by turning it upside down! Anyway. I pulled the spark plug and replaced it with a new one. Still it doesn't start.
Old 12-28-2009, 12:11 PM   #6
Spark plug was soaked. I replaced it but it still doesn't strat. Any other suggestions?
Old 12-28-2009, 12:16 PM   #7
47_47's Avatar
Rewards Points: 44
Do you have the safety key fully installed?
Old 12-28-2009, 12:46 PM   #8
Safety key? There is a key, it's installed and turned to the on position.
Old 12-28-2009, 04:36 PM   #9
Safe, Most of the Time!!
brokenknee's Avatar
Here is a link to a manual for a Tecumseh 2-cycle.
http://www.cpdonline.com/692508.pdf
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 12-28-2009, 11:34 PM   #10
007
DIY - 007
Try using some Starting Fluid by spraying it into the carb or spray some into the spark plug hole and give it a try.
If too much oil got in there (if you don't really know the whole full story on how it happened) it could be fouled up by the oil.
I had a similar case this fall (not the same as yours) and after playing with it for a little bit with the starting fluid, she's up and running now like new again.
You 'may' need to take the fuel bowl off and clean it out, again the starting fluid will clean things up nice for you.
Give it a try and see how it goes.
007 is offline   Reply With Quote
Asphalt repair in snow country Steve Burke Building & Construction 2 09-19-2009 06:34 PM
snow blower repair darren28 Automotive Repairs 1 12-26-2008 01:03 PM
Snow blower repair Gregoryj Appliances 4 12-21-2008 08:52 AM
Snow Blower Repair Labrador General DIY Discussions 5 06-03-2008 01:26 PM
Snow Blower problem gregryan999 General DIY Discussions 2 02-14-2008 01:55 PM
