Slow Coolant Leak - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-01-2013, 07:14 AM   #16
Ole Wood Worker
BigJim's Avatar
Rewards Points: 768
My wife's car was doing that, I did use the stop leak but it never did stop the leak. It turned out to be the water pump, that was so much fun.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-09-2013, 05:34 PM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Stay away from the leak stoppers.
Check the water pump weep hole as well.
Old 12-09-2013, 06:55 PM   #18
Still Decompressing
Rewards Points: 273
Water pump leaks can be tricky. Hard to see and may fade in, and out. You may also have a leak thats aggrivated by driving motion, so it did not show up when the car was on the lift. I have also had minor hairline cracks in radiators that were hard to spot.
I would avoid the stop-leak / bars-leak. More trouble than they are worth, IMHO. There is a product that GM used to ad to Saturn Alum block engines. Don't 100% remember the name, (goldenrod??). I am pretty sure they still sell it at NAPA. Its small round gold tablets. Anyway, GM had problems with Porocity in some of their aluminum blocks, and this was how they dealt with it, so it can't be all that bad.
caveeagle is offline   Reply With Quote
Mystery Leak Running Out Of Ideas... miamicuse Roofing/Siding 30 08-15-2013 08:47 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 05:45 PM
Slow leak under sink after fixing clog gunzour Plumbing 4 11-30-2009 09:27 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
