Slip Sliding Away. The Transmission That Is. - Automotive Repairs - Page 4 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree16Likes
Old 12-22-2016, 12:38 PM   #46
Bigplanz's Avatar
Rewards Points: 996
Re: Slip sliding away. The transmission that is.
Originally Posted by de-nagorg View Post
Didn't you say that "Jimmy", had these replaced once before?
What corrodes them so fast?
New England salt on the streets?
Good of GOODYEAR to look and not charge.
You do need to have this leak stopped, before it causes a real expensive problem in the transmission.
ED
I am assuming the car being in NYC for 16 years takes a toll. Brake caliper mounts were rusted solid. Guys at the oil change place had a struggle getting the skid plate off. Everything under the car (nuts/bolt heads) are rusted. I can get it looked at next week.
Goodyear by my house has been fair. I had to replace a steering knuckle on the villager once because the bearing was so bad the new bearing would fit right in the knuckle. Goodyear was ok with me bringing in a knuckle I got at a junkyard and just charged me labor to put it in.
de-nagorg likes this.
Bigplanz is offline   Reply With Quote
Old 12-22-2016, 07:32 PM   #47
Bigplanz's Avatar
Rewards Points: 996
This is the part that is leaking.
http://www.autozone.com/drivetrain/t...?checkfit=true
Old 12-24-2016, 08:36 AM   #48
Bigplanz's Avatar
Rewards Points: 996
And now... this...
Flat tire, chuck out of the sidewall, plus dry rot. Another new tire for Christmas!!
Old 12-24-2016, 03:16 PM   #49
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
I hope they just sell you one. Does it have a 2wd mode?
I hate signatures.
Mort is offline   Reply With Quote
Old 12-24-2016, 03:49 PM   #50
Bigplanz's Avatar
Rewards Points: 996
I got a new tire. That one was in bad shape. It is AWD, with 4WD hi and lo options.
Old 12-24-2016, 04:04 PM   #51
Mort's Avatar
Rewards Points: 694
That's good, a lot of places will only sell you all four when it's AWD. Messes with the transfer case when they aren't the exact same height.
I hate signatures.
Old 12-24-2016, 04:44 PM   #52
Bigplanz's Avatar
Rewards Points: 996
255 75 17 is the size. I have replaced the worst two (perelli's) already. Brand new wranglers @ $190 a pop. The other two look a lot better.
Sliding door and window leaking Esanders323 Windows and Doors 6 01-12-2016 04:39 PM
how to remove closet sliding doors young707 Windows and Doors 8 08-04-2013 06:07 PM
Help with DIY Slip n Slide Project ffrllc General DIY Discussions 9 08-05-2011 06:47 PM
PVC Slip coupler msaeger Plumbing 5 03-13-2011 09:46 PM
Condensation on baseboard by sliding doors... Donmills Flooring 0 06-28-2010 08:35 PM
