Silverado Humming Noise - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-12-2011, 08:20 PM   #1
Stairguy
Millertyme's Avatar
Rewards Points: 508
Silverado humming noise
I have a 2000 silverado 4wd. I was getting a humming noise from what sounds like the front end (hard to tell). I can hear it best when on the highway at about 65mph. I notice it more when i let off the gas, although I think it still remains while giving it gas. The noise does not go away when I swerve from side to side. I thought it might be wheel bearing but I wasnt sure what side. I bought a new one and put it on the drivers side. The noise remained so I put it on passenger side and that didnt help either. If it is not wheel bearing, what else could it be? The sound it makes is like driving down the highway with huge tires on.
Millertyme is offline   Reply With Quote
Old 06-12-2011, 09:44 PM   #2
Sounds like a front diff going out
D-rock is offline   Reply With Quote
Old 06-13-2011, 05:53 AM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
is there any way to diagnose this problem?
Old 06-13-2011, 06:46 PM   #4
You sort of already did, you narrowed out bearings, tires make noise regardless of pedal load, front diff whines differently under load and no load. Try shifting into 4wd and see what the noise does, see if it changes. It may be best to take it to a shop so they can drive it up on a rack and listen from under the vehicle. A front diff rebuilt probably isn't cheap. You can have a fluid service done, see if any nasty metal pieces and stuff comes out. it has a magnet on it to catch pieces (i think)
Old 06-14-2011, 08:49 PM   #5
ukrkoz's Avatar
Rewards Points: 952
hey, i have same noise! have 2000 Silverado LT extended cab. it does not humm all the time, but does it after extended drives. humm comes somewhere from right below the front row seats. it's faint and is irrelevant to RPMs. it comes driving or now, so diff theory is not working. you can sit in P and step out and hear it.
to me, it sounds like a pump working. whoooooooooooooooooooooooooooooo. the only thing that is in that area is transmission. i had this asked about a year ago in Chevy forum, no one knows what it could be. it drives fine. i stopped paying attention to it.
maybe it is fuel pump working? also, there's some sort of a pump in transmission too.
ukrkoz is offline   Reply With Quote
Old 06-16-2011, 08:51 PM   #6
Stairguy
Millertyme's Avatar
Rewards Points: 508
definitely not fuel pump. I just did it 2 years ago. Its inside the massive 33 gallon tank. im gonna check my gear oil in front differential tomorrow.
Old 06-16-2011, 09:08 PM   #7
ukrkoz's Avatar
Rewards Points: 952
keep in mind, mine does that humm driving or not. i can park, step out, and hear it. it is more pronounced on the driver side, right about where cab ends and bed starts. like i said, there are only transmission and fuel tank there. btw, fuel pump is all the way up in the tank, not buried inside of 27 gallons of gas. mine is 27, not 33.
Old 06-16-2011, 09:37 PM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 110
Maybe it hums, because it doesn't know the words.
Sorry, couldn't resist.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-16-2011, 10:07 PM   #9
ukrkoz's Avatar
Rewards Points: 952
i have enough words cometh out of my wife's mouth. lord save me from my truck start talking to me.
The Following User Says Thank You to ukrkoz For This Useful Post:
drtbk4ever (06-18-2011)
Old 06-17-2011, 03:15 PM   #10
So Millertyme, does it make the noise driving and sitting at idle?? or just driving, that will make a big difference where you look. Extended cab trucks have a 26-27 gallon tank, regular cab with long bed have 33-34 gallon tank.
Old 06-18-2011, 08:03 AM   #11
Stairguy
Millertyme's Avatar
Rewards Points: 508
no it only makes the sound when i am going about 65. I hear it more when i let off the gas. As a matter of fact it seems to be getting quieter every day. Although I never really did anything...well i changed the wheel bearings on both sides and it didnt work. it still made the sound but now it seems to be slowly going away.
Old 06-18-2011, 08:33 AM   #12
Have you just tried to rotate the tires to narrow that out?
Old 06-18-2011, 10:32 AM   #13
ukrkoz's Avatar
Rewards Points: 952
WELL, MAYBE JUST LET IT GO AWAY AND DON'T BECOME OBSESSED WITH IT. sorry, forgot caps were on. it's a GM truck. supposed to make all kinds of noises by design.
Old 06-18-2011, 03:32 PM   #14
Stairguy
Millertyme's Avatar
Rewards Points: 508
thanks ukrkoz thats what i was thinking. im only looking to get about 8 more months out of this truck then ill be getting a new one. It just hard when the thing is paid off, it makes me not want a new truck , it nice having no payment.
Old 06-18-2011, 03:35 PM   #15
ukrkoz's Avatar
Rewards Points: 952
don't sell it. drive it to death. be nice to it and keep it. nothing is better than paid for vehicle. why would you get yourself into debt again? it starts? drives you where you need to? hauls? what else do you need? oh, i know. small subwoofer, so you don't hear that humm. $140 amazon, no big deal.
Slight humming noise. wjconrad HVAC 2 01-10-2011 06:20 PM
Humming noise when air handler turns on redfish99 HVAC 1 08-24-2010 11:44 AM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 11:25 AM
Loud humming noise from electric forced air furnace MissBehavin HVAC 9 01-02-2009 05:14 PM
