Signal Light Flashing Fast- Busted Bulb? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-25-2014, 03:58 PM   #1
Rewards Points: 1,062
Signal light flashing fast- busted bulb?
People,
BMW 328i, 2009, when I turn right, I get the green arrow on instrument cluster flashing very fast, and occasionally, warning image is displayed (an image of a "bulb"). Thing is, I turned it on and walked around car, since it happens only on right turn, I figured it has to be either front or rear PASS side. But they BOTH flash fast- front AND back. So, How do I figure which one has a broken bulb?
Tips appreciated.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 04-25-2014, 05:29 PM   #2
I think its the rear- when blinking fast, some of the LED "rows" do not flash/light up. Still dont know how to yank the assembly/replace.
Old 04-25-2014, 05:50 PM   #3
Oso954's Avatar
Rewards Points: 1,132
Should be a little access hatch inside the trunk, behind the light assembly. Open and release and pull the wire connector. Should be 3 small nuts (8mm?) that hold in the assembly.
Oso954 is online now   Reply With Quote
Old 04-26-2014, 06:09 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,790
Pull the connectors and inspect them one by one.
Old 04-26-2014, 11:58 AM   #5
Geez, howd you guys know that?? Wow, you guys really know BM's!! Thaks! Now, I got that opened up, and can see the 3 nuts. easy, BUT, what happens when I yank the unit, can I repair those LED lights /welds solder joints?? That unit costs about $100 new.
Thanks!!
Old 04-26-2014, 11:59 AM   #6
Oh- shoulds mentioned that I checked again, knowing that the culprit might be a row of led's, and when flashing (fast), theres a row that is dead. So, gotta be either the led's or connections. Anyone here know about led's?
Old 04-26-2014, 12:12 PM   #7
could this be what I need:
http://www.carid.com/2009-bmw-3-seri...-10268384.html
Old 04-26-2014, 02:18 PM   #8
Oso954's Avatar
NO !
Those are LED's to replace the ordinary bulbs that were used on various 3 series cars.
You have the OEM LED assembly. It is normally replaced as a unit.
The Following User Says Thank You to Oso954 For This Useful Post:
noquacks (04-27-2014)
Old 04-27-2014, 02:46 PM   #9
Originally Posted by Oso954 View Post
NO !
OK, Os- I appreciate your advice (even though you yelled at me to do this correctly.....LOL) Youre a good teacher! So, Os, guess that bad news is I cant fix this, I have to buy new. At least I know. Last thing- WHY , on that link, is it stated that those bulbs are for 2009 bmw 3 series (I have a 328i), which is my car?? Bad info? Bad advertising? For other 3 series like 335, etc?
Old 04-27-2014, 05:14 PM   #10
Oso954's Avatar
The 328I came as a sedan, wagon, coupe and hardtop convertible body styles. Not all used the same tail lights. Some had the LED, some had regular bulbs.
You earlier mentioned being able to buy the whole light assembly for about $100. If you can, that is a great price. But, be sure it is the LED assembly not the regular bulb. l would expect the LED assembly price to be higher.
noquacks (04-28-2014)
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
fluorscent light, two bulb 8 feet long. cavers Electrical 6 11-22-2011 08:03 AM
How to install an outlet to a light bulb fixture. enforcefx Electrical 2 10-17-2011 08:08 AM
light bulb won't fit Norene Electrical 3 03-15-2010 06:48 PM
How to remove light bulb casing rhymer59 Electrical 6 03-10-2009 09:26 PM
