Shaking Silverado - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-07-2011, 07:40 PM   #1
Stairguy
Millertyme's Avatar
Rewards Points: 508
shaking silverado
I have an extended cab 4wd 2000 silverado. The truck shake a little at exactly 20mph. I notice it more when i am giving it gas. I can feel the vibration in the pedal. Its fine once it hits 25 but will do it again at 60mph. I also make a weird clanking sound, usually when the truck is cold, which only happens at low speeds but goes away once i get moving. It sounds like it is coming from behind be. I was thinking driveshaft. What do you guys think. How can i troubleshoot it?
Millertyme is offline   Reply With Quote
Old 07-07-2011, 08:00 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
sounds like a driveshaft u-joint. jack up the truck so rear wheels are off the ground and check for play in the joint. If there is any, replace it
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 07-07-2011, 09:57 PM   #3
ukrkoz's Avatar
Rewards Points: 952
pull out drive shaft and lubricate splines in yoke. super typical for GM trucks.
shake at low speeds - you need to give more info.
ukrkoz is offline   Reply With Quote
Old 07-08-2011, 07:45 AM   #4
Rewards Points: 104
I believe that Mr. Chips and Ukrkoz have you on the right track, so I would definitely proceed as they described. Along with that, although I think they have been discontinued, and don't know if they were still using them in 2000, or not, check to see if your rear drive shaft is one piece or two, and, if two, check that all three u-joints are synched, or oriented the same. Also, my brother had a GM pickup sometime around then that had a composite driveshaft, which he had to replace, due to an incurable imbalance.
Old 07-09-2011, 06:59 AM   #5
I think only the reg cab with longer beds still use a two piece with a center carrier bearing assembly, but I do agree, sounds like a drive shaft issue.
D-rock is offline   Reply With Quote
Old 07-09-2011, 08:37 AM   #6
ukrkoz's Avatar
Rewards Points: 952
well, he needs to be less worried about yoke. that slow speed shake points either towards trannie or ignition issues, and that is more important. those trucks are known to clunck and rattle into hundreds of thousands of "start and go" miles.
Old 07-09-2011, 09:49 AM   #7
Rewards Points: 256
sounds like a ujoint , i would change it cause they are not greasable and need to be replaced eventually anyways , plus its cheap and will eliminate 1 possible cause if its not the ujoint. always go with the 'spicer' brand if you can .
oldrivers is offline   Reply With Quote
03 silverado speedometer wetz Automotive Repairs 15 10-22-2015 11:17 AM
Silverado humming noise Millertyme Automotive Repairs 20 01-24-2012 09:59 PM
Warning to all Chev Silverado owners Sampson Automotive Repairs 2 01-01-2011 10:44 PM
1998 F150 or 1997 Silverado Z71? jpearson311 Automotive Repairs 8 09-30-2010 02:00 PM
99-02 Silverado Repair Manual...? jaysen Automotive Repairs 6 09-24-2008 01:01 PM
