Security System Reset - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-11-2012, 05:38 PM   #1
Rewards Points: 37
security system reset
Hello,
My 08 silverado has a short somewhere because yesterday the day runnning lights were on and the washer fluid pump was running. I disconnected the pump and removed the fuse for the lights. I recharged the battery and it would not turn over. The battery was tested and only had 6 volts with no load after 6 hours on the charger. New battery and it still wont turnover no clicking. All electronics work, just no clicking. Someone mentioned possibly the theft system may need to be reset. How do I do this?
nbmech is offline   Reply With Quote
Old 08-15-2012, 03:31 AM   #2
Search for "reset passlock system" on google. Here is one example:
http://www.saturnfans.com/forums/sho...d.php?t=114514
Maybe the procedure there will help you...
freedomlives is offline   Reply With Quote
Old 08-15-2012, 11:45 PM   #3
Have you tried to perform a draw test ?
Carkid0007 is offline   Reply With Quote
Old 08-24-2012, 08:27 AM   #4
Rewards Points: 37
UPDATE...
It turns out the body control module, transmission control module, transfer case control module and engine control module were all bad. After talking with a neighbor he remembered hearing a close lightning strike. I guess that could have possibly caused the issue. The dealer is asking GM to assist with the repair cost.
Thanks for your help.
Old 08-24-2012, 09:59 AM   #5
Man, that sucks.
It is possible for lightning to induce current, but unless your car took a direct hit, I'd say GM should cover the costs because it seems like a bit under-engineered if lightening can induce enough current in so many mechanisms to fry them. That's what may have drained your battery in the first place as well-- the lightning may have latched some transistors on which then turned those other components on.
Old 08-28-2012, 08:50 AM   #6
Rewards Points: 254
We had one come into the shop like that with lightning damage. Their insurance paid for the repair I would give them a call.
cjm94 is offline   Reply With Quote
Old 08-29-2012, 12:44 AM   #7
Yea I doubt you get Gm to pay for a lightening strike, but your insurance is going to be the best bet. We had one come in that fried every module in the vehicle as well..ecm,tcm,bcm and so on and so forth.
Installing Pool System New v. Used? flowerchick General DIY Discussions 5 10-27-2011 08:28 AM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Anyone have a home security system? kristiamy Safety 1 10-17-2010 09:54 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
