Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-19-2012, 06:08 PM   #1
Saturn door lock solenoids chattering
My 1998 Saturn SL2 has a door lock/unlock problem. Whenever a 'lock' or 'unlock' button is pressed, the solenoids start chattering. Sometimes they go on for some time, even starting up by themselves. Yesterday the battery went dead from this. Help!
Whipsnake is offline   Reply With Quote
Old 06-20-2012, 01:26 PM   #2
47_47's Avatar
You may have a bad or corroded lock relay. It should be in the underhood fuse block. Swap it with another.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
Whipsnake (06-25-2012)
Old 06-20-2012, 04:28 PM   #3
like 47 47 said, or I've have also seen faulty lock/unlock switches where the contacts will continue to touch after pressing them, or even just from a bump
D-rock is offline   Reply With Quote
The Following User Says Thank You to D-rock For This Useful Post:
Old 06-25-2012, 08:23 PM   #4
Turned out to be the lock/unlock button assembly. $25 & 1/2 hour later I was back in business. Thanks for your replies & advice
BTW, this Saturn has been one of the worst POS cars I've ever had. One thing after another. Its sole duty nowdays is my tow car behind my motorhome. Glad Saturn is out of the gene pool.
Solenoids, water intrusion, and reuse adoggg Electrical 1 12-15-2011 12:23 PM
contactor chattering, replaced it- still have chatter sprinkle100 HVAC 7 10-27-2010 06:10 PM
