Saab '97 Turbo 900 SE AC Leak - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-06-2008, 05:41 PM   #1
Question
Saab '97 Turbo 900 SE AC leak
Car wasn't cooling properly. Ac tech added freon and injected a dye into the AC system to help find the leak. After system stopped cooling a few months later, tech (w/o having the system running) said that the dye which can be seen with special glasses was on two hoses that run from the condenser to evaporator, etc. and suggested the replacement of both hoses. Does the presence of the dye on the hoses mean for certain that the hoses are leaking or could the dye be leaking from somewhere else and spraying on the hoses? His prescription was going to cost $600+.
How should it be checked to be sure that is where the leak is? Just the old soappy water way?
LONIGRO6969 is offline   Reply With Quote
Old 11-07-2008, 07:19 AM   #2
47_47's Avatar
Rewards Points: 58
Been out of automotive for 6 years, but when I put dye in, I used a UV light with the engine off to check for the presence of the dye. The glasses may be a new way.
You will see the dye at the leak. There may be dye traces from the air flow through the engine compartment on non-leaking parts. If the dye was spraying from a leak, the charge wouldn't have lasted a few days, let alone a few months. Soapy water will not find a leak.
You could take the car to another repair shop and tell them that dye was installed and let them tell you where they feel the leak is (second opinion) or trust the first tech.
47_47 is online now   Reply With Quote
Old 11-07-2008, 08:31 AM   #3
AC Saab '97
Thank you for the reply. Yes, he used the UV light and the glasses.
Will take it to a second tech.
Old 11-13-2008, 07:19 AM   #4
I would have thought that after the dye was injected you'd run the a/c for a bit right away and see if you could see a leak. Maybe drive a way for a day or two using it periodically and come back to check, but a few months later. This would prevent any distribution via spraying, air flow, running, etc... and one could be more confident in the solution.
cmittle is offline   Reply With Quote
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 08:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
Leak on gas heater water line? darsunt Plumbing 3 04-16-2008 03:57 PM
