Rust Remover - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-25-2010, 04:44 PM   #1
Rust remover
I have a trailer that is starting to get quite a bit of rust built up on it. I'm wanting to take care of the problem before it starts eating through and I need to patch. I've looked into Rust Guy but it is pretty expensive. If it works I would have no problem spending the money but I'm having trouble finding a lot of info on it other than their own website, which I think might be slightly biased. Has anyone used this product or is there any other rust remover/preventive paints that you would recommend? Thanks!
nosbusch2005 is offline   Reply With Quote
Old 08-25-2010, 05:23 PM   #2
Enough is Enough
H. A. S.'s Avatar
Online, there are tutorials on how to remove rust, try Googling 'electrolysis'.
Long time ago, there was a guy who dunked his whole trailer frame, hooked up the charger, and it looked like new.
H. A. S. is offline   Reply With Quote
Old 08-25-2010, 06:31 PM   #3
If you can find me a tub that I can dunk a 38' Semi trailer in I'll give it a shot
Old 08-25-2010, 07:00 PM   #4
fabrk8r
fabrk8r's Avatar
Look for someone in your area that does sand/media blasting. It's usually not very expensive and the results are bare metal ready for primer.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-26-2010, 04:28 PM   #5
Don't know it all, yet!
I have used the rust converter products for about tweny years and had good results. This is the stuff that goes on and changes the rust to a black primer like surface that can be painted. Or left as it is.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 08-26-2010, 09:35 PM   #6
Well I am going to order some and give it a try.
Old 08-30-2010, 09:53 AM   #7
Rewards Points: 152
Eastwood is the biggest name vendor in this space that I know of. Also there is POR 15. Either of those should do the trick. If its only slight surface rust that I want to stop or at least slow down. A liberal dose of WD 40 a few times a year is a simple/cheap alternative.
piste is offline   Reply With Quote
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 06:02 AM
Rust on Grille of Outside Condenser Unit (photos) Carol2 HVAC 2 06-01-2009 04:02 PM
Surface rust on stainless steel rjniles Appliances 8 04-05-2009 06:55 PM
bathroom sink rust removal? bofusmosby Plumbing 4 11-12-2008 06:28 PM
fertilizer fleecing? Wisco Landscaping & Lawn Care 3 08-24-2008 06:14 AM
