-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Rust converter (phosphoric acid) not working (http://www.diychatroom.com/f46/rust-converter-phosphoric-acid-not-working-175993/)
Studly 03-31-2013 07:06 PM
I'm trying to fix a rust spot on my car cheaply and quickly, so it looks better when I sell it soon. I've read rave reviews about Ospho, which is mainly phosphoric acid, and lots of people recommended a generic version called Prep & Etch, which is only $15 at Home Depot for a gallon.
I bought the Prep & Etch, which is also phosphoric acid based, and brushed off the loose rust, cleaned it and applied the P&E. Just a small part of the rust spot turned black, but there was still lots of visible rust showing through. I figured that because it was a vertical surface, maybe it didn't stay wet for long enough and that's why it didn't work. So on another day, I cleaned the rust spot again, and put about 8 coats of P&E on it, spaced out over about a 30 minute period. Still the rust shows through, and the spot is still more orange than black.
I also tried the P&E on some rusty tools, and they too still appear rusty.
Did I get a bad batch of this stuff or am I doing something wrong? Others who have used this who've posted on other forums talk about the amazing results this stuff has on anything that is rusty.
ukrkoz 03-31-2013 09:53 PM
Always get what you paid for.
This one works.
http://www.jamestowndistributors.com...ct.do?pid=2584
Thurman 04-03-2013 08:51 PM
From experience working on older cars: I have used two different brands of this "Ortho" type rust neutralizers, and neither were big box store diluted solutions. Both of the solutions I have used plainly state something to the effect: "More than one coating of this material will not neutralize the rust better than a single properly applied coating." Maybe the stuff you buy at a big box store has been diluted way too much to work properly. Automotive paint stores carry the somewhat "professional" solutions and they are worth the pricing. I have used a brass bristled (fine bristles) brush to rub the solution in while it is still wet. Wiping off with something clean before it dries.
BirdSlapper 05-02-2013 06:57 PM
I've had great success with POR-15 from an auto body supply shop. First, grind all rust out, then use the prep stuff for a few coats and let dry. Then apply the POR-15 for a few coats. It will turn black and stay that way as long as the area isn't forced to constantly sit in salt water. I treated the lower inner doorskins and lip of the tailgate of my old Ford truck then had it Ziebarted. 4 years later when I traded it in (should have kept it) no sign of rust anywhere.
