Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-19-2011, 05:09 PM   #1
Question
Reverse lights & top stop light
I have a 2000 Mercury Sable Wagon. I can't get the reverse lights or the upper stop light to work. I replaced all bulbs and put in a new reverse light switch which sits over the trans. I took all the panel off the hatch (seen no breaks in wire) all fuses are good. Don't see any broken wires under steering column. Is there something I did not do when replacing the reverse light switch? I need HELP!
Determined is offline   Reply With Quote
Old 09-19-2011, 05:19 PM   #2
Learning by Doing
Leah Frances's Avatar
Might have a bad relay.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
Determined (09-20-2011)
Old 09-19-2011, 05:31 PM   #3
a wiring diagram would probably help you out, there might be a break in the wire from the relay to the switch, check for power from the relay to the switch wire, also a break from the fuse panel to the third light before the hatch
christoff is offline   Reply With Quote
The Following User Says Thank You to christoff For This Useful Post:
Old 09-19-2011, 05:36 PM   #4
Thanks both of you. I will look into this.
Old 09-19-2011, 06:53 PM   #5
DIY Hack
Mr Chips's Avatar
my moneys on a bad ground
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
Old 09-20-2011, 11:19 PM   #6
I thank you for your in put, it worked. The only problem was, I was wondering where to start to look for a bad ground. After checking all the wires into the fuse box under the steering I found no broken wires. Oh man, now what? I then checked the boot which goes into the hatch on both sides and sure enough one broken pruple wire and one broken black wire. Spliced them together and now everything works fine.
Ceiling fan light kit duhtroll Electrical 10 06-21-2011 03:29 PM
Suggested Amount of Light HooKooDooKu Electrical 2 04-13-2010 04:31 PM
wiring lights from existing light fixture raineydr Electrical 6 03-25-2010 06:18 PM
Lights not full power Pinky22786 Electrical 4 02-01-2009 10:39 AM
activate other lights when motion light activates John Electrical 3 02-10-2004 08:53 PM
