Replace Rear Caliper - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-18-2009, 11:43 PM   #1
sweaty
Rewards Points: 276
I have a 2001 Nissan Sentra SE with Brembo rotors and Akebono pads. The right rear caliper started dragging and the mechanic said I need to replace both- $156 each for just parts. This seemed like a lot and he is willing to use my aftermarket parts. What caliper should I get? Should I replace both?
sweaty is offline   Reply With Quote
Old 06-19-2009, 03:57 AM   #2
Oldguy
Rehabber's Avatar
8 years is a long time on calipers - replace them both or you will probably be doing another early brake job.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 06-21-2009, 08:59 AM   #3
Sweaty, Pep Boys used to have re manufactured Toyota calipers, so they probably have Nissan ones as well.
If you have Brembo components now, don't skimp on Chinese aftermarket parts, get the goods ones unless you're unloading the car soon.
Chemist1961 is offline   Reply With Quote
Old 06-21-2009, 09:11 AM   #4
i suggest asking this question here:
http://www.nissanforums.com/forum_index.php
it may be possible to clean up the slider pins and pad brackets and save the old calipers and some money.
they may even have some for sale over there too.
gregdonovan is offline   Reply With Quote
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
Rear Window Seal Crista Automotive Repairs 2 11-18-2007 11:16 AM
rear entryway/stairwell LanterDan Remodeling 1 11-02-2006 12:32 PM
