Repair Cracked "plastic" Bumper Cover? (Ford Escape) - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-26-2008, 05:56 AM   #1
Repair cracked "plastic" bumper cover? (Ford escape)
Girlfriend hit a deer. No major damagae front bumper is cracked in a few places. It's not painted just looks like asemi flat black.
Is there any glue that would do a good repair?
rossl56 is offline   Reply With Quote
Old 12-26-2008, 11:57 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Nope,...
Replacement is the Only fix for those things...
Bondo is online now   Reply With Quote
Old 12-26-2008, 05:19 PM   #3
Replacement is your best option... But there is a PlastiWeld kit, that is like soldering/welding with plastic instead of metal... It is an art form to get it right, and works best when painted afterwards...
nperkins is offline   Reply With Quote
Old 12-29-2008, 10:55 AM   #4
I am going to give this a try:
http://www.permatex.com/products/Aut...astic_Weld.htm
Old 12-29-2008, 12:10 PM   #5
I've used the bumber repair kit a couple of times and it works well. I've always unsed it on painted bumpers, however. If you just want to hold things together and you are not too concerned about appearance, it should work fine. If you want it to look like it did originally, you could probably, bondo, sand, prime and paint with automotive paint, or replace it entirely.
KHouse75 is offline   Reply With Quote
Old 08-27-2009, 05:34 AM   #6
Originally Posted by Bondo View Post
Nope,...
yeah,,and plastic bumper doesn’t cost much..heres a diy that would help you how to change plastic bumper cover..
kurtdaniel is offline   Reply With Quote
Old 08-27-2009, 08:03 AM   #7
The Permatex plastic weld worked very well. The spot I had to repair was on the bottom and not visible.
Cracked dashboard repair... trentv123 Automotive Repairs 1 08-05-2008 09:28 AM
Repair cracked glass cooking hob Anto318 General DIY Discussions 2 01-03-2008 12:24 PM
Can I cover old cracked vinyl flooring with lauan and new vinyl? MikeC. Flooring 4 03-12-2007 05:20 AM
