Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-12-2007, 12:08 PM   #1
Removing Polyurethane Overspray for cars paint finish...
Recently I made the mistake while spraying polyurethane onto a wood project of not covering my car first. It was parked about twenty five feet away but it managed to recieve the spray on it. I now have a fine polyurethane spray mist all over the upper portion of my car. I have tried a couple of different grades of Rubbing Compound and one (coarse grade) worked well for the windows. I cannot use that same grade on the paint however.
Next, I used turpentine on the entire painted surface and in one area I rubbed and rubbed using paper towels as the applicator and then using dry paper towels rubbed the same area again very hard. That seems to be doing the job but also seems like there MUST be an easier, quicker way.
Any ideas?
Much appreciated!
Thank you for your time.
Norm...
Norm is offline   Reply With Quote
Old 11-12-2007, 01:42 PM   #2
I have gas!
Clutchcargo's Avatar
Try going over it with a quick wipe of lacquer thinner. I once used it to strip the the wax off my white painted car because the white was getting kind of off-white. It's the best bug and tar remover I've found as well. Make sure you get a fresh coat of wax when you're done.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-12-2007, 05:40 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
That depends on the car
Car finishes have changed greatly over the years, and what will work fine on a Bavarian Millennial Clearcoat can dissolve the finish on your '80s Mullet Muscle IROC
slickshift is offline   Reply With Quote
Removing paint from hardware ciera Painting 11 09-10-2007 10:03 PM
How to paint 2 different colors with a knockdown finish? klemmy Painting 17 04-09-2007 05:15 PM
Removing spray paint from tools harold938 General Discussion 15 12-17-2006 08:16 AM
Removing Paint from Bricks ? Piney Painting 7 11-16-2006 02:17 AM
Removing paint from hardwoods amclaugh Flooring 4 09-17-2005 09:49 AM
