Rebuilt truck
You most likely have the 4L60E transmission....with those 35's it's about par to starting off in 2nd gear.
Your gas mileage is going to suffer and your not going to have much pulling power....
To solve the problem, regear...at a min, 4:10 gears in the rear...maybe even 4:56. It will make a big difference.....it will 'wake up' the truck.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
