Rear Tire Makes Clunking Noise - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-11-2011, 08:08 PM   #1
Rewards Points: 338
In my wife's Dodge Neon, if we take a turn that puts the weight to one side of the car, the rear tire on that side (passenger) will start rhythmically clunking. The faster you are going the faster the clunking, and as you slow down, the clunking will slow down. Turn in the other direction to move the weight to the other side of the car, and no clunking. The clunking can be heard quite well from the trunk, as the back seat is pretty thin. I am thinking strut?
Any ideas??
dougp23 is offline   Reply With Quote
Old 11-11-2011, 08:20 PM   #2
A Little Of Everything
Rewards Points: 1,364
The fact that the speed of the clunking increases with the speed of the car indicates that it's something on the wheel/tire. I'd check several things:
1. Check your tire pressure.
2. Check the tension of your lug nuts. It's possible that they are loose.
3. Check the tightness of your wheel bearing.
If you've got a lot of miles on the car, it's possible that your wheel bearing is not just loose, but is shot.
DrHicks is offline   Reply With Quote
Old 11-11-2011, 08:32 PM   #3
Rewards Points: 558
The clicking/clunking noise you are hearing is coming from your rear CV boot. Check to see if the boot is cracked and grease is leaking out. If so, then dirt entered the boot causing damage to the CV axle. You will have to replace the complete CV axle shaft.
epson is offline   Reply With Quote
Old 11-11-2011, 10:41 PM   #4
ukrkoz's Avatar
Rewards Points: 932
they ever made AWD Neons?????? with rear axle shaft?
year of your Neon helps..
anyhow, strut it might be. or rear hub bearing under load. or even tire itself. do simple test - swap out tires on that side, and see what happens.
did you try to vigorously rock that side of vehicle? to maybe duplicate that clunk?
rear stabilizer bar can do that too, it has large rubber bushing that can go bad.
ukrkoz is offline   Reply With Quote
Old 11-12-2011, 09:17 AM   #5
Also check for rust build up on the rear brake drums, doubt it has disc brakes, but it does sound to be in the suspension or brake area as it is rotational with vehicle speed
D-rock is offline   Reply With Quote
Old 11-13-2011, 10:12 AM   #6
Rewards Points: 254
I agree with something in the brakes or wheel bearing.
cjm94 is offline   Reply With Quote
Old 11-13-2011, 12:16 PM   #7
Household Handyman
Rewards Points: 1,408
Dodge Neon= wheel bearing problem. Period. Jack up only this side until the tire is free of the ground, turn tire slowly, with ear near tire, listen as it "rattles/grinds". Inherent Dodge Neon problem.
Old 11-13-2011, 12:40 PM   #8
The shock is shot!
A strut is comprised of a spring and shock. The shock has lost its valves, and your basically bouncing on the spring.
Master of Cold is offline   Reply With Quote
Old 11-13-2011, 03:19 PM   #9
Rewards Points: 338
Wow! So many opinions! I am sending her to the shop this week, will report back what the mechanic says!
Thanks everyone.
Old 05-02-2014, 10:11 PM   #10
same problem.
So, I'm having same issues, 05 sxt. 102,000 miles after new tires developing problems. Have the clunking noise coming from left rear when turning right. Changing the wheel hub (bearings) tomorrow and struts couple days after. Hoping its the problem. Also anyone here have leaking trunks? Lol.
zx69r is offline   Reply With Quote
Brand new Coleman 97.5% furnace makes horrible whining noise junebuggy HVAC 10 11-15-2016 10:53 AM
Kitchen Faucet makes a CLUNKING sound!! jcdonkey Plumbing 19 09-09-2013 04:37 AM
GE Refrig Makes Noise jinks Appliances 7 11-02-2007 07:22 PM
Comfortmaker makes noise on start up JHIDS HVAC 2 03-04-2006 12:41 AM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
