Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-05-2011, 06:40 PM   #1
Re-setting a garage door opener
I have a garage door opener that needed its battery replaced, so I did. Now it doesnt seem to want to work
I know some garage doors can have their remotes reset. Anyone know about how to do this?
Or any other trouble shooting tips?
phantasm72 is offline   Reply With Quote
Old 08-05-2011, 07:14 PM   #2
Remodeler
What brand is the opener?
How old is the opener?
Do you have other remotes that work?
iamrfixit is offline   Reply With Quote
Old 08-05-2011, 07:50 PM   #3
DIY Hack
Mr Chips's Avatar
Many of them have a reset button under the light cover on the main unit. Sometimes you just need to press the reset button, then press the remote within 20 seconds or something, sometimes it's more complicated.
Best bet is to google a manual for you brand and model number, or post it here to see if someone can help
If it was me, i would test your new battery or swap in a "known good one" just to rule out the simplest possible solution
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-08-2011, 04:44 PM   #4
ukrkoz's Avatar
out of my experience with gate openers, go for biggest baddest battery your opener can tolerate.
but indeed, your best bet is to look up manual online.
never realized they have battery operated garage door openers, though it does make sense for power outages. my gate runs 200 cycles on battery if so needed. but it came with a dinky little 12V battery, and all I had was hassle, until I swapped it for full blown marine deep cycle battery. been few years, not a prob..
ukrkoz is offline   Reply With Quote
Old 08-08-2011, 10:40 PM   #5
yeah, battery is ok. Little light on the main unit flashes away when the remote is pushed, but nothing happens. So its obviously receiving a signal, it just doesnt know what to do with it...
Old 08-08-2011, 11:09 PM   #6
ukrkoz's Avatar
so was it a garage door opener battery, or garage door opener REMOTE battery?
Old 08-08-2011, 11:11 PM   #7
ukrkoz's Avatar
you need to re-synch garage door OPENER and opener REMOTE now. on mine, i put opener into learning mode, and press and hold open button on remote, with remote about 3-4 inches away from opener. light on opener flashes then turns solid, and that's it.
Old 08-11-2011, 05:44 AM   #8
On a lot of these doors,all you do is press the botton reset button,on your opener, till light comes on,now hold your remote towards the light,and press your remote button four times.This will reprogram your remote.Should work;Mack
BigMack is offline   Reply With Quote
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Garage Ideas? tripflex General Discussion 13 12-16-2009 08:06 PM
Electrical problem in garage ginaca Electrical 10 04-19-2009 07:51 PM
