Radiator Hose Change - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-02-2008, 05:08 PM   #1
I need to change my upper and lower radiator hoses. Is it possible to do it in a particular sequence to minimize losing antifreeze? If not, I need to have an idea what the total amount of coolant is needed. And what is the typical ratio of anti-freeze to water? I have a '95 Nissan Quest XE mini-van.
Thanks in advance!!
capt2 is offline   Reply With Quote
Old 02-02-2008, 05:18 PM   #2
Eibwen
Drain the radiator from the petcock into a container using a funnel. Plastic milk jug, etc. Have several on hand.
Dont just let it run out on the ground as it is toxic to pets/animals.
The amount drained should about equal what you need to put back in plus any that didnt make the container. Your owners maual should have a capacity for a full drain.
As far as the new mix, I use 50/50 but consult the temp chart on the back of the anti-freeze for expected coldest temps in your area.
Sammy is offline   Reply With Quote
Old 02-02-2008, 06:16 PM   #3
I have an appliance tray (a two inch high plastic container thats about 4 inches wider than a washing machine) that I use any time I'm repairing my cooling system to catch any anti-freeze. If my anti-freeze is providing proper insurance against freezing and it's between my regular clean and flushes, I just re-use it. Like Sammy said drain the radiator using the drain spout into a bucket or like container. My truck doesn't have a drain spout so I drain by pulling off the lower hose and use the above appliance tray for any spills from both radiator side and engine side.
Wondering why you are replacing your two hoses? Good luck and let us know how your project turns out. Cliff
UBoiler is offline   Reply With Quote
Old 02-04-2008, 01:49 AM   #4
Thanks for all the replies!
Need to change my electrical panel? 2nd opinion needed I_have_questions Electrical 60 01-30-2009 10:38 AM
Hard to change position/size of windows? zel General DIY Discussions 20 07-13-2007 08:30 AM
Considering Room Addition & Roof Change pkthomas_ar Building & Construction 4 05-02-2007 07:41 PM
change steam radiant heat to outside wood water heat Monteu HVAC 5 02-13-2007 12:19 PM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 07:54 PM
