Radiator Hose - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-10-2013, 07:55 PM   #1
Rewards Points: 164
Radiator hose
I just changed water pump and radiator toy chevy 1500 truck everything looks great but the hose going to the radiator on top of thermostat it shrinks when I shut off truck, why??? When I take off radiator cap it goes back to normal is everything running properly??? What is it??? Help
bostonwindows30 is offline   Reply With Quote
Old 03-10-2013, 08:30 PM   #2
Buy a quality hose, you could put a spring in it, but it should not have a spring in there.
paintdrying is offline   Reply With Quote
Old 03-10-2013, 08:32 PM   #3
Rewards Points: 164
Do you think it's the cap? It's not venting properly??
Old 03-10-2013, 08:39 PM   #4
Rewards Points: 13,270
New hose?
I always change all the hoses and belts when I change the pump. Got them off anyway.
Old 03-10-2013, 08:40 PM   #5
Rewards Points: 164
I did that I changed all hoses,
Old 03-10-2013, 08:41 PM   #6
Rewards Points: 164
Or do you think it's the thermostat????
Old 03-10-2013, 08:45 PM   #7
If memery serves me the top hose is suppost to be the one with wire in it.
No wire, it collapes and can cause over heating.
Old 03-10-2013, 08:46 PM   #8
Rewards Points: 164
Ok I will change it out, thank you
Old 03-10-2013, 09:22 PM   #9
Rewards Points: 692
The suction hose has the spring wire. Ever see a stat with little hole about not much bigger than a needle. I wonder what the purpose of that hole is.
SeniorSitizen is offline   Reply With Quote
Old 03-11-2013, 10:25 AM   #10
Master General ReEngineer
Bondo's Avatar
Rewards Points: 602
Ayuh,... That's an air bleed hole, so's the block will fill as ya fill the radiator....
The bottom hose from the radiator is the suction side, block water is exhausted to the radiator through the top hose...
Old 03-11-2013, 10:27 AM   #11
Rewards Points: 164
So do I need to get different hose??
Old 03-11-2013, 03:13 PM   #12
r0ckstarr's Avatar
Rewards Points: 1,996
Yes. Change the cap. They are cheap. Your cap is not allowing the cooling system to pull in coolant from the overflow bottle, creating a vacuum, and collapsing the hose.
r0ckstarr is online now   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
Windows on Wash (03-12-2013)
Old 03-11-2013, 04:57 PM   #13
Rewards Points: 164
So do I need to change the hose???
Old 03-11-2013, 06:47 PM   #14
Rewards Points: 254
No it will do that as it cools. As stated if you have an overflow tank make sure the hose is clear and replace the cap
cjm94 is offline   Reply With Quote
Old 03-11-2013, 07:03 PM   #15
Rewards Points: 164
Will do, thanks for the help
