Proper Percentage Of Anti-freeze - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-07-2009, 07:25 PM   #1
Lightbulb
proper percentage of anti-freeze
hello,..I am installing an outdoor wood burner and I need to know if any one can give me solid information as to the correct anti-freeze to water mixture rate? any good advice is very appreciated. thxs
timothyhot is offline   Reply With Quote
Old 09-08-2009, 07:12 AM   #2
Rewards Points: 150
Does your Boiler manufacturer even recommend it! Most people I know do not use any in their system. I haven't used any on mine since new 5 years ago.
Gary
Gary_602z is offline   Reply With Quote
Old 09-08-2009, 04:36 PM   #3
You'll want to contact the manufacturer of the equipment/system. I talked to the maker of my boiler yesterday about the issue and they allow/recommend 30% mixture of Fernox Alphii or No Burst glycols.
mics_54 is offline   Reply With Quote
Old 09-08-2009, 06:35 PM   #4
Safe, Most of the Time!!
brokenknee's Avatar
Gary
You must live in a fairly warm climate; no antifreeze in MN would mean you would never shut down the system. I know that is the plan (not to shut down) but what if you go on vacation for a week in January?
I would check with the manufacture, it may vary depending on what part of the country you are in.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 09-09-2009, 08:01 AM   #5
Rewards Points: 150
I am in MI so it is not a cold as MN. But running a 30% mixture? that would be 30 gallons on a 300 gal system.
Gary
Old 09-09-2009, 05:44 PM   #6
brokenknee's Avatar
Gary
30 gallons on a 300 gal system would be 10%; 90 gallons would be 30%
Old 09-11-2009, 07:09 AM   #7
Rewards Points: 150
Told you I was from MI didn't I? But what I mean't was it would be a large cost for the antifreeze.
Gary
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
Anti Freeze OK to use in sprayer? brokenknee Painting 10 03-30-2009 07:36 PM
proper material for service grounding rod? Jim S. Electrical 9 02-05-2009 10:25 PM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 04:56 PM
What is the proper ventilation needed? Ice Damns causing problems. alanisaacson Roofing/Siding 1 01-07-2005 02:38 PM
