Problem With Rebuilding A Starter Motor - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-13-2013, 07:13 AM   #16
PoleCat's Avatar
Rewards Points: 1,646
The winding in the solenoid can be fine and pull in the plunger but the actual contacts can be worn out and no longer making good connection.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
noquacks (12-13-2013)
Old 12-13-2013, 05:31 PM   #17
Oso954's Avatar
Rewards Points: 766
The pic is a Ford starter and solenoid, but they all look generally alike.
To test out of car, connect a strong 12V power source (eg car battery and jumper cables to the unit). A weak source may not power the motor.
The Negative can clamp to one of the starter mounting ears.
If you touch the positive Briefly to terminal "M" the motor should spin. Stand clear as you do this, the motor is liable to jump/roll from the torque.
Touching the positive to terminal "S" should operate the solenoid, but not the motor.
To test the whole thing, clamp the positive to terminal "B". Then use an old screwdriver or insulated wire (w/ ends stripped) to jump some power from "B" to "S".
Again, be prepared for the motor to move.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
noquacks (12-15-2013)
Old 12-15-2013, 11:11 AM   #18
Rewards Points: 1,062
Good to know, oso- I will try that very soon.....
update:
I went through this entire tedious test method:
http://www.ehow.com/how_8197179_test-dc-armature.html
The armature checks out!! I cant figure this dang thing out. Spent sooo much time on it already. sheesh. Not giving up yet, though. Einstien said "so many otherwise breakthroughs are missed when the experimenter gives up just before the discovery is about to be manifested". Or something like that- please feel free to correct the quote.........
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 12-15-2013, 12:42 PM   #19
revellation!! Einstein was right!! I followed Oso's steps above, and man, touching M terminal with Pos voltage sparks!! Smokes!! I immediately pulled it away, of course. Then, I put an ohmmeter on the M and base (ground) and I get continuity (0.3-0.4 ohms) where I should get infinity(right?)!! Im shorting the motor out somehow!! What the heck did I do wrong, people????!!!!
Oh- touching terminal S like it says above does make the solenoid "pop" out, pushing "clutch" forward. So, that part of it is OK. I assume because of that solenoid is good(?) Keep in mind, I didnt do anything to the solenoid before dismantling the motor- and it worked nicely before with old brushes (before dismantling to put on new brushes).
Old 12-18-2013, 04:48 PM   #20
finaly got it, man, what a finicky situation- starter shop blew out some spec of dust, apparently, cuz they too were puzzled as to why it was shorting out. They repeated it 2X, take apart, mount it together. Finally, blew out minor dust with compressor, and it started. But, we were on the right track, people. Im glad yous were there to see me through it- we tried our best.
Big thanks to all here.
ELectric motor issue RWolff Electrical 23 06-22-2013 01:41 AM
Old Rheem Air Blower Motor Wiring Problem CompoundNetwork HVAC 3 11-20-2011 04:51 PM
Outside condenser fan motor stops tatums4 HVAC 21 10-12-2011 09:17 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 06:13 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 07:30 PM
