Problem With Rebuilding A Starter Motor - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-10-2013, 05:23 PM   #1
Rewards Points: 1,062
problem with rebuilding a starter motor
People,
Bosch starter, before dismantling it, I tested it with 12v, and clutch popped out, starter motor turned. It had about 100,000 miles on it, and the car did have trouble starting with that one, so yanked, it, put in new, and now trying to rebuild this one until the instaled one quits.
So, bought a new brush kit, spec'd out the bushings, and cleaned it up a bit. I believe I put it back together all ok......LOL
So, then, applied 12v to the rebuilt starter, and no start. Motor makes no sound at all. Clutch though, does pop out. man, where did I go wrong? I did notice a tad of smoke (sooo tiny), from the batery clamp connection point (12v is from a car battery, with jumper cables). other than that, no go.
Tips/condolences apreciated.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 12-10-2013, 05:44 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
All the wires hooked to the right poles?
Old 12-10-2013, 05:56 PM   #3
I believe so. Hey, maybe I switched the poles of the solenoid?? I mean, if poles of solenoid are switched, would the clutch still pop out? I kinda doubt it, but not 100% sure......
Old 12-10-2013, 09:43 PM   #4
Rewards Points: 14,294
There is no clutch on a starter, do you mean Bendix?
http://www.prestolite.com/pgs_training/training_4.php
Old 12-11-2013, 06:33 AM   #5
There is a "clutch" on a starter. Ever take one apart/look at a diagram? At least, thats what people call them, guesss we could call them something else. Whats a bendix (without me looking it up on wikipedia)?
Old 12-11-2013, 06:44 AM   #6
PoleCat's Avatar
Rewards Points: 1,652
I can't remember now which one is which but one type uses inertia to propel the gear into place while the other uses a magnetic solenoid to pull a plunger that drives the gear into place. If the solenoid is attached to the starter this is the type with the plunger.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
noquacks (12-11-2013)
Old 12-11-2013, 07:01 AM   #7
http://www.2carpros.com/articles/how...solenoid-works
Old 12-11-2013, 10:03 AM   #8
Remodeler
Rewards Points: 330
Did you clean up the commutator that the brushes run against? If so you probably shorted it out. The small spaces between the commutator segments can be easily contaminated with metal or carbon particles from cleaning and end up shorting out the armature.
I wouldn't bother with it, If you bought a quality rebuilt or new unit it will likely last as long as the original, not worth keeping it around in storage. Pretty small cost given the length of service. Usually a rebuilt unit will either fail quickly during the warranty period or last a very long time.
iamrfixit is offline   Reply With Quote
The Following User Says Thank You to iamrfixit For This Useful Post:
Old 12-11-2013, 04:39 PM   #9
magnetic solenoid- plunger, with spring, activates the clutch, with a fork, ......but again, thats not the problem- the clutch works. The problem is the MOTOR.
Old 12-11-2013, 04:45 PM   #10
Yes, fixit, I did clean up the commutator, and the stacks. Shop manual says to do that. Now, if I shorted it, did I ruin it? Not clear on that- I followed the usual method of sanding down slightly the copper area, with fine grit, then dusted off.
The rebuild is junk. Squeals like mad upon start up. This original Im trying to rebuild is OEM Bosch, made in Germany. The bushings are even better condition than the new ones included in the rebuild kit for this starter! So, I kept them on.
Thanks, fixit.
Old 12-11-2013, 04:53 PM   #11
nice article, joe- now I know the bendix is the sprocket "gear"- whatever- still, the article confirms the starter has a clutch.
Old 12-11-2013, 06:07 PM   #12
took it apart, checkd commutator for ohms to shaft, and I get no circuit/infinity (thats a good unit, I understand), indicating no shorting (right, guys??)
put it back together. will batery test it tomorow, too late for me now- bedtime. Also, dark outside.
Thanks, people.
Old 12-12-2013, 06:00 AM   #13
PoleCat's Avatar
Did you do anything with the solenoid? The plunger also is the contact for the big current that drives the motor. The contacts must be clean and free of oil, not burnt to a crisp etc. The plunger must be able to slide evenly so it slams all the way in and doesn't get lodged in its sleeve.
noquacks (12-12-2013)
Old 12-12-2013, 05:45 PM   #14
thnaks, pole. Thinking about it- contacts are clean/no burnt. Now, remembering, before I took the whole thing apart, the starter DID work (I probably did not make that clear). So, solenoid, I assume should be OK. Right?
Also, doesnt it mean solenoid is ok since now it at least, does move the clutch forward into position. just that at that point, no motor activation. I mean, according to one source, that IS the solenoid go/no go test.
Wanted to try it today, but no time to jump it with batteryu cables. but dont worry, I wil get back to yous hopefully by sunday. Big thanks for your support in this perplexing matter, people!!
Old 12-12-2013, 06:18 PM   #15
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 180
I have a Ford starter here that I rebuilt for the same reason. All these part store parts seem to be junk anymore. I just changed the fuel pump on my work van three times before I got one that worked. The new window motor that I put in the driver's side a couple months ago has already quit.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
ELectric motor issue RWolff Electrical 23 06-22-2013 12:41 AM
Old Rheem Air Blower Motor Wiring Problem CompoundNetwork HVAC 3 11-20-2011 03:51 PM
Outside condenser fan motor stops tatums4 HVAC 21 10-12-2011 08:17 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
