Problem With New Taillight Assembly - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-27-2013, 07:43 PM   #1
Rewards Points: 422
Problem with new taillight assembly
I just put on a new taillight assembly from Certifit, and the backup light and brake lights won't work. The turn signal is fine. Where the bulbs plug into the connectors, it is rusty. What do you guys suggest to clean the rust? I assume the rust is the problem. It's a 2003 Chrysler Town and Country. Thanks.
Jim McC is offline   Reply With Quote
Old 06-27-2013, 07:53 PM   #2
Rewards Points: 254
Get a new connector pigtail. You will never get all the corrosion off and destroy the new light assy.
cjm94 is offline   Reply With Quote
Old 06-28-2013, 12:13 AM   #3
Rewards Points: 422
Thanks. Where do I get one? What's involved in switching it out?
Old 06-28-2013, 06:28 AM   #4
Rewards Points: 254
Might be able to get one from a better parts store. Or the dealer should be able to. It will have a short length of wire attached. Then use butt connectors that have shrink wrap built in to prevent corrosion at the connection.
Old 06-28-2013, 10:12 AM   #5
Rewards Points: 422
Thanks. Before I go to that trouble, is there a way to make sure the new taillight assembly isn't bad? It has 3 separate bulbs, by the way(Brake, backup, turn signal).
Old 06-28-2013, 10:58 PM   #6
Rewards Points: 83
Just go to the dealer and buy new sockets, there not easy to look up but if you find someone that knows what there doing they can find the part number, at first they will tell you that you will need the asm. but a TSB came out on replacing the sockets.
streetneons is offline   Reply With Quote
Problem with toilet (vent problem?) branch155 Plumbing 24 03-09-2012 09:37 AM
Boiler Question regarding Pilot Relite Control & Ignition Electrode Assembly stevepatts HVAC 0 02-22-2012 08:42 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 08:19 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
