Power Steering Pump Replacement Issues - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-30-2009, 09:54 PM   #1
power steering pump replacement issues
well i replaced my power steering pump on my 92 Saturn SC because it was leaking and its not anymore. My mom has a 98 Saturn and its real similar to the car i have ( I'm talking under the hood at least ). But on her car there is like a real hard plastic hose that is connected to the part attached to the motor that goes to the PS pump to put the three screws. ( i hope i didn't get every one confused ). well it was never connected on mine. I'm talking about that part that looks like a backward "C" where the 3 screws of the PS pump go into.on the screw that goes like at 7 o'clock there is a hose under the pump that if i lift it a little it falls right onto a hole where i could probably fit a screw just like the other ones,but there wasn't one there to begin with.
  • NOW IF I'M SUPPOSED TO PUT A SCREW IN THAT HOSE AND IT DOESN'T HAVE IT WOULD THAT BE FOR MY CAR TO HEAT UP.
***IMPORTANT***
MY CAR HEATS UP BUT NOT ALWAYS. IT STAYS IN THE MIDDLE BUT IF I'M DOING 60 FOR 5 MIN OR MORE IT WILL SLOWLY START GOING HIGHER AND HIGHER BUT WHEN IT GET TO 3/4 OR THE LINE BEFORE THE "H" I GET OFF OF THE EXPRESS WAY AND RIGHT AWAY IT GETS TO THE MIDDLE AGAIN.
Any help will be appreciated
joey219 is offline   Reply With Quote
Old 10-08-2009, 12:19 PM   #2
Resident Computer Guru
I thought we solved the overheating issue in the last thread? As for your issue.. take pictures of said hose/hole/etc.
newbsauce is offline   Reply With Quote
Old 10-08-2009, 04:14 PM   #3
47_47's Avatar
Rewards Points: 44
Because the Saturn does not have a grill opening the outside air was engineered to flow over the radiator by the air deflector and air dams. I was told that missing or damaged air dam components could cause overheating, but I never seen this happen.
If you checked the cooling fan and the ECT like I told you in your other post, and they are working properly, only one other thing comes to mind. Saturn put in coolant sealant pellets from the factory and they could be blocking the passages in the block or head. I used to flush them by removing the block drain (by the water pump), remove the upper hose at the engine, remove the cap at the resevoir and alternately put a garden hose into the upper hose and the water outlet at the head. A good flush will open them, but you may cause leaks.
The basic engine shape of the 92 and 98 looks the same, but there are many differences and most part are not interchangeable.
Like newbsauce asked post a picture about the hose.
47_47 is offline   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Where to look when you have power issues with your pc... rgsgww PC Repairs & Upgrades 1 11-15-2008 07:08 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
