Power Steering Fluid Leak :( - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-27-2008, 02:10 PM   #1
power steering fluid leak :(
Does anyone have experience with Lucas Power steering Stop Leak or similar? Does it work? can it be used in any type of vehicle?
http://www.lucasoil.com/products/dis...tid=2&loc=show
Any other products or do I need to go shell out he bucks to my mechanic.
thanks
pesphoto is offline   Reply With Quote
Old 08-27-2008, 07:03 PM   #2
shell out the bucks....unfortunately the "stop leak" products usually clog the system and stop flow as well as leaks. this goes for any kind of stop leak for any fluid system in a motor. never good stuff to use.
robbie2883 is offline   Reply With Quote
Old 08-28-2008, 04:28 AM   #3
Oldguy
Rehabber's Avatar
The stop leak formulas for power steering WILL NOT clog anything up. The chemicals in them are designed to soften the seals that have hardned over time. Worth a try, I like K & W trans-X.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 08-28-2008, 10:56 AM   #4
Thanks guys! I did email with my mechanic last night and he told me it's worth a try. He knows my car pretty well. So I bought some of the Lucas Oil stuff. Just waiting for the level to go down a bit more before adding it in. How many people can say they have a mechanic that will email them advice!!
Old 09-24-2008, 11:30 AM   #5
Personally
Personally I would never put any form of stop leak in any automotive system! I can't tell you how many times Ive seen ATF in power stearing systems, that is usually the cause of the line leaks. Replacing lines is one thing, and quite a pain on some modles, but even more expensive to the client is when either the rack or the steering gear leaks!!!!!!
sssalas is offline   Reply With Quote
Old 09-24-2008, 12:19 PM   #6
the Musigician
DangerMouse's Avatar
my mechanic suggested i add "Lucas transmission fix" to mine when he did a flush and filter, seems to have worked out quite well. no more slipping and no more noise in my 35 yr old truck.
DM
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
