Power Steering-cant Keep Topped Up - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-28-2010, 12:46 PM   #1
Power steering-cant keep topped up
1997 cavalier. I've filled it up with those stop leak products but still can't keep it topped up. I cannot see any visible leaking.
Thoughts?
Possible easy fixes?
Thx
fjacky is offline   Reply With Quote
Old 11-28-2010, 01:02 PM   #2
Bigplanz's Avatar
Rewards Points: 952
Start the car, let it warm up. Turn the steering wheel from one side to the other about ten times, slowly. Don't stress the steering, just gently turn from one side to the other. Then open the hood and check the pressure line fitting at the pump. If it is wet, you've found your leak. If not, then you have a leak down at the rack (probably). It's almost always the pressure line that leaks. If you can get under the car safely, you can DIY but it's messy and you have to replace the power steering fluid. The pressure line on my Olds was a PITA. I was filthy when I was done, but didn't spend $180 for the repair either. Tip: wear safety glasses under the car. It is a rain of crud that comes down when you take the line off. One of those plastic hair cover things like they wear in commercial kitchens is a good idea too. You will get FILTHY.
Bigplanz is offline   Reply With Quote
Old 11-28-2010, 06:08 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,... Exremely Unlikely....
Bigplanz has a good plan to find the problem,... Ya just gotta Look harder....
Bondo is online now   Reply With Quote
Old 11-29-2010, 12:52 PM   #4
47_47's Avatar
Rewards Points: 44
Agree with Bigplanz, remove an inner tie rod bellows boot clamp. It is probably storing the fluid.
47_47 is offline   Reply With Quote
Old 11-29-2010, 01:42 PM   #5
(the original)
Rewards Points: 756
Yup, had that problem recently with my daughter's '01 VW Cabrio. The fix is replace the rack with a rebuilt. Replacing the seals isn't a DIY job and most shops won't mess with racks these days, they just swap it out and send the old one to a rebuilder. The Cabrio is a PITA to work on, many are easier, don't know about the Cavalier. Good luck!
ratherbefishin' is offline   Reply With Quote
Old 11-29-2010, 06:53 PM   #6
Bigplanz's Avatar
Rewards Points: 952
Replacing a rack on a Cavalier isn't particularly 'hard' but it is a challenge for anyone without the right equipment. Pull the boot, if fluid comes out, yeah, replace the rack is the only sensible solution. I checked, and a new one can be had at Autozone for $150. The PITA parts are: getting it out (major PITA, which can involve pulling out the power brake booster if it is in the way of above access) and which will require some jackstands, an impact wrench (good one) to get the bolts off and (maybe) dropping the frame rail five inches to pull the thing out through the wheel well. Yeah, it's that fun of a job!
Then, you have to drain all the fluid, which isn't really hard since it is gonna come gushing out when you disconnect the lines, but you should replace the pressure and return line and the pump too if you are replacing the rack. The pump and lines get crud in them and that crud will go straight into your brand new rack, thus, well, ruining it. Pump, $40, return line $54, pressure line $32, Oh, and new fluid.
Essentially, you are replacing the entire power steering system on a 13 year old car for about $300 and 10-12 hours of DIY work.
You might want to just keep topping it off.
Old 11-30-2010, 07:21 AM   #7
47_47's Avatar
Rewards Points: 44
Another word of caution, make sure that the steering wheel is centered and locked before removing the old rack from the steering shaft and the new rack is centered before installing. If not, you will damage and need to replace the SIR coil.
Old 11-30-2010, 12:27 PM   #8
(the original)
Rewards Points: 756
And DISABLE THE AIRBAGS!
fjacky, what stop leak did you use? Lucas is the only one I've ever found to really work, and then only if it's just minor seal leaks.
power steering pump replacement issues joey219 Automotive Repairs 2 10-08-2009 04:14 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 08:26 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
