Power Inverter - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-28-2013, 09:04 AM   #1
Bigplanz's Avatar
Rewards Points: 990
power inverter
Will a 750w inverter overstress the battery/alternator? Emergency use only, no continuous heavy draw. 95 merc villager.
Bigplanz is offline   Reply With Quote
Old 10-31-2013, 07:24 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,346
Nope,... Shouldn't,...
Old 10-31-2013, 01:51 PM   #3
Oso954's Avatar
Rewards Points: 1,106
It is not the size of the inverter, but the size of the load that will determine how much workload is put on the battery/alternator.
If you did load up the inverter to its max, 750w/12v=62.5 amps. Throw in about 15% for the inverter inefficiency and you are looking at almost 72 amps on the 12v system.
If the engine isn't running, it will not take long for the battery to be too low to start the vehicle.
Even with the engine running, smaller vehicles at idle may not produce as much as the load, and you could have a drain on the battery.
Oso954 is offline   Reply With Quote
Old 11-05-2013, 02:10 PM   #4
Be careful with power inverters. There are a lot of junk products out there.
My dad used to do medium haul trucking and used a laptop in the truck. He had several power inverters MELT. I finally hard wired one into the truck for him which worked a lot better. You get what you pay for I suppose...
AJPLeBlanc is offline   Reply With Quote
AFCI Breakers not working - inverter power ptarmigan61 Electrical 2 05-20-2013 06:51 PM
Power Inverter for air mattress beh162 General DIY Discussions 12 04-24-2013 05:02 PM
Dishwasher Power Supply Captain.Sassy Electrical 14 09-14-2011 05:28 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 09:43 AM
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
